FWX_E_TCP_NOT_SYN_PACKET_DROPPED
All Forums >> [ISA 2006 Firewall] >> General >> FWX_E_TCP_NOT_SYN_PACKET_DROPPED Page: [1]
FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 9.May2007 10:25:18 AM
xcoder
Hi;
I began to use ISA server 2006 and zywall firewall
(ADSL modem > Zywall > isa 2006 > intranet)
When I want to login yahoo.com..
Isa Initiated a Connection to  yahoo.com's ip and download some of page
then isa was closed connection before page not complately display
at last localhost try to connect yahoo again
but isa was deny connection
(isa said the reason is FWX_E_TCP_NOT_SYN_PACKET_DROPPED) ??????
Thanks..
< Message edited by xcoder -- 9.May2007 10:26:33 AM >
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 20.May2007 11:18:54 AM
Is there a rule allowing access to the site?
Are the clients configured to use HTTP 1.1 through proxy connections?
(in reply to xcoder)
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 21.May2007 5:02:36 AM
xcoder
Generally My client aren't configured to use HTTP 1.1 proxy
there is only one rule for access to the site. I try to direct access but notting change.
this is my logs.. Why localhost(-External-) try to connect ??
I dont use router because I have only one subnet for internal network..
192.168.1.myip = internal computer/network
192.168.3.isa     = external network/isa
Thanks..
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 22.May2007 8:36:02 AM
Enable HTTP 1.1 through proxy connections and see if that fixes the problem.
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 22.May2007 9:28:39 AM
xcoder
ORIGINAL: tshinder
I enable http1.1 proxy but nothing change :(
I saw -isa external ip goes to internet all my web request- in my log.. is it normal?
< Message edited by xcoder -- 22.May2007 9:30:19 AM >
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 23.May2007 11:07:23 AM
In its role as Web proxy, the ISA Firewall does generate a new request.
This ISA firewall has a least two NICs, right?
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 24.May2007 1:55:59 AM
xcoder
Yes there is two NICs.
I tryed it on webproxy,securenat and firewall client, this result code(Not sycn) came all times..
But securenat client to reach yahoo.
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 25.May2007 12:35:00 PM
Perhaps a bug in the Zywall? Is the definition of the ISA Firewall's internal network correct and the internal and external interfaces are on different network IDs?
