Faild Publish Webserver With Isa2004
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Faild Publish Webserver With Isa2004 Page: [1]
Faild Publish Webserver With Isa2004 - 2.Apr.2008 3:08:49 AM
goldman
Hi, Everyone
I tried to publish webserver with isa2004 but i faild
My Network config.
- Router with static ip :like  1.1.1.1
- Isa server2004 with 2Nic cards
1-Ext: 192.168.1.64        GW: 192.168.1.254
2-Int: 192.168.2.55    without GW
I used route add
- Windows server2000 - IP: 192.168.2.66 - Domain Name : xxx.com
- WebServer  192.168.2.77
I can ping from / to any host
Internet work good .
I Follwed this to Publish :
http://www.isaserver.org/tutorials/Creating-Configuring-Non-SSL-Web-Publishing-Rules-Part1.html
and:
http://www.microsoft.com/technet/isa/2004/plan/publishingwebservers.mspx
i used WebServer ip 192.168.2.77 in the Define Website to Publish form
i used static ip :1.1.1.1 in the Public Name details form
i used Ext Nic for iza 192.168.1.64 in the Web Listener form
- in the router conf. i forward http to ISA Ext IP.
- when i write my static ip in the browser http:\\1.1.1.1
Nothing happen .
- are there any rule i must do it in access policy ?
***** Help me Plz .*****
< Message edited by goldman -- 2.Apr.2008 3:12:18 AM >
RE: Faild Publish Webserver With Isa2004 - 19.Apr.2008 1:24:33 PM
mlg
It sounds as if your problem is dns related. Check the TCP/IP properties for the ISA routerīs external nic. These fields
should be filled:
IP Address
Subnet Mask
Default Gateway
The two DNS fields must be blank ... if IP of your external DNS is entered here all request for your index.html will be redirected to your external DNS
(in reply to goldman)
