Failed Connection Attempt
All Forums >> [ISA 2006 General] >> General >> Failed Connection Attempt Page: [1]
Failed Connection Attempt - 30.Jan.2008 3:15:46 AM
wshamroukh
    I have an ISA server 2006 Enterprise Edition installed on win2003 server... I created an access policy to allow HTTP and HTTPS from localhost/local network to External Network(internet)... when i browse for example to http://www.gmail.com the page will take time and then i will get an error like this:
Error Code 10060: Connection timeout
when i go to the logging page of ISA server, I see the action coloumn this message:
So what is the problem here guys? can you please help me?
RE: Failed Connection Attempt - 30.Jan.2008 12:47:53 PM
Enable Web Proxy listener on the localhost network.
Make the browser on the ISA Firewall a Web Proxy client.
(in reply to wshamroukh)
RE: Failed Connection Attempt - 31.Jan.2008 12:24:14 AM
wshamroukh
Web Proxy on both localhost, internal networks is alreadt enabled on port 8080... I configured the browser on the ISA server to point itsself in proxy connection... but still most pages come out with the error
 and the logging page is logging the same action
any other suggestions??!?!
RE: Failed Connection Attempt - 31.Jan.2008 11:17:50 AM
gofishin
Do you not need to add the Internal Network to the source networks on the web access rule you have created. Cheers
RE: Failed Connection Attempt - 31.Jan.2008 11:22:14 AM
Hi Gofishing,
Yes, the source would be Internal and destination external.
Web proxy client configuration sets the browser to using the IP address on the Internal interface.
(in reply to gofishin)
RE: Failed Connection Attempt - 3.Feb.2008 12:37:37 AM
wshamroukh
let me tell u how my ISA server is connected to the network
my isa server is connected only to LAN, the other network interface is not connected.. the lAN interface's default gateway is a sonicwall firewall which is connected to router. my network looks like this:
Internet -------> router -------> sonicwall -------> ISA ------->LAN
has the network something to do with this issue.. i mean the error i get when i open a website and a get Failed Connection Attempt
thanx in advance
RE: Failed Connection Attempt - 3.Feb.2008 3:21:11 PM
You need to configure the ISA Firewall as a back end firewall behind the sonicwall. In that way you get full functinoality and it will fix problems you're having right now.
RE: Failed Connection Attempt - 4.Feb.2008 5:47:57 AM
wshamroukh
but what if i want to keep my network design as it is... is there another solution of moving the ISA server to the backend of my network?
RE: Failed Connection Attempt - 4.Feb.2008 7:11:51 AM
gofishin
Sounds like it might be a routing issue - does the Sonicwall firewall perform the NAT translation? If so, then you need to set up a route Network Rule in ISA rather than a NAT rule. If not, then the reverse.
I have a checkpoint firewall at both sides of the ISA array in a back firewall config - the ISA server just bridges 2 DMZ's..
RE: Failed Connection Attempt - 4.Feb.2008 3:03:37 PM
You will need to do some small reworking of your network to support the ISA Firewall, since it's the back end Firewall, you need to configure you clients behind the ISA Firewall to use it as their Internet gateway.
RE: Failed Connection Attempt - 7.Feb.2008 12:24:22 AM
wshamroukh
i will take this into consideration.. thank you all for ur help
RE: Failed Connection Attempt - 11.Sep.2008 5:15:09 AM
wshamroukh
i did what u all saying but still i am getting the same error.. have a look at this post
http://forums.isaserver.org/m_2002073482/mpage_1/key_/tm.htm#2002073482
