Failed Connection Attempt
Failed Connection Attempt - 18.Aug.2008 3:27:48 AM
mrjahnara
Dear All, Please find below the error , ISA server is keep on logging whenever outlook configured in the Client Pc's are trying to access External Exchange Server. Failed Connection Attempt Log Type: Web proxy(Forward) Status : 995 The I/O operation has been aborted because of either a thread exit or an application request. Note: Even there is an error in the ISA logs, Outlook is still working but taking long time to send or receive mail. Please any body help me to solve this problem. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 18.Aug.2008 9:16:17 AM
mrjahnara
Yes Outlook is configured to access https://mail.getgroup.com Exchange server. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 18.Aug.2008 10:04:32 AM
mrjahnara
How do i check the authentication in the rule? I Simply created a default rule to allow all the outbound traffic to all the users. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 19.Aug.2008 10:17:45 AM
mrjahnara
I have created a new rule to allow all outbound traffic from internal to external. New Rule --->All Outbound traffic---> Internal Network---->External Network -----> All Users. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 21.Aug.2008 8:46:56 AM
mrjahnara
No. Even i allow all the outbound traffic, the error message is appearing. Thanks Abdul Rahuman.M
RE: Failed Connection Attempt - 21.Aug.2008 10:08:28 AM
mrjahnara
Their default gateway is the router which is directly connected to the internet. Please note , the ISA firewall client is installed in all the client machines. Thanks and Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 22.Aug.2008 10:25:10 AM
mrjahnara
Yes , all the machines including ISA server are in the same Domain. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 24.Aug.2008 12:36:52 PM
Are the Firewall clients successfully connecting to the ISA firewall? Is the Firewall cliient configuration updating the Web Proxy client configuration correctly? Tom
RE: Failed Connection Attempt - 25.Aug.2008 4:11:16 AM
mrjahnara
All the Firewall clients are working well , all the users are browsing fine. The error is occuring in the server only, when anyone browse the htpps site and working on outlook since it is configured to access exchange server through https. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 26.Aug.2008 1:58:26 AM
mrjahnara
Yes , you are correct. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 26.Aug.2008 8:38:58 AM
OK, that sounds like the rule you created to allow outbond HTTPS connections has a path limitation or maybe you set it to restrict to certain MIME types. Also, if you set an HTTP Security Filter setting for the SSL rule, it might block connections too, since the firewall can't see inside the SSL tunnel without using ClearTunnel. HTH, Tom
RE: Failed Connection Attempt - 26.Aug.2008 10:10:35 AM
mrjahnara
Thanks for your kind response again. I havent block any outbound traffic. I have created only one rule which is to allow all the outbound traffic to external network from internal. Regards Abdul Rahuman.M
RE: Failed Connection Attempt - 28.Aug.2008 8:15:01 AM
I'm out of ideas. Maybe you can find somebody local to look at your firewall configuration. I'm sure it's something simple that somebody knowledgeable about the firewall will be able to easily fix. HTH, Tom
