Failed Connection Attempt - HTTP Status Code 13
Failed Connection Attempt - HTTP Status Code 13 - 5.Apr.2005 5:22:00 PM
tjcarst
I am pulling my hair out on this one. I have allowed all users access to this address. If I set my clients to bypass ISA and go through my external hardware firewall, it is successful. Any ideas here would help me save what's left of my hair.
--- Error --- (received on Windows 2000 & Windows XP Web Proxy/Firewall/SecureNAT clients)
"Unable to establish secure socket, error = 336130315 error:1408F10B:SSL routines:SSL_3_GET_RECORD:wrong version number"
"Unable to establish connection with host. The SSL handshake failed."
--- ISA Log ---
Original Client IP: 0.0.0.0 Transport: TCP Log Record Type: Firewall Destination IP: 65.16.47.152 Destination IP: 80 Protocol: Action: Donnection failed Source Network: Internal Destination Network: External
Firewall Client Application Settings: Application: BZMD.PRO Key: Disable Value: 0 Key: DisableEx Value: 0 [ April 05, 2005, 11:30 PM: Message edited by: tjcarst ]
RE: Failed Connection Attempt - HTTP Status Code 13 - 5.Apr.2005 9:55:00 PM
tjcarst
The breakdown appears to happen here:
Original Client IP: 0.0.0.0 Bytes Sent: 2153 Bytes Rec: 102 Result code: 0x80074e24 HTTP Status Code: 13 Log Record: Web Proxy Destination IP: 65.16.47.152 Destination Port: 80 Action: Failed Connection Attempt
Any ideas? My hair is thinning....
Thanks.
tjcarst
RE: Failed Connection Attempt - HTTP Status Code 13 - 7.Apr.2005 5:43:00 PM
tjcarst
I have spent hours on this and have made no progress.
Has anyone else any ideas?
RE: Failed Connection Attempt - HTTP Status Code 13 - 13.Apr.2005 10:40:00 PM
Hello,
Any luck with this? I am running into a similar issue.
cwilliams@capcomfcu.org
RE: Failed Connection Attempt - HTTP Status Code 13 - 15.Apr.2005 8:36:00 PM
tjcarst
No luck yet. I'm completely bald now...
RE: Failed Connection Attempt - HTTP Status Code 13 - 29.Apr.2005 6:15:00 PM
Try turning off the Web Proxy Filter in the HTTP protocol definition.
RE: Failed Connection Attempt - HTTP Status Code 13 - 30.Jun.2005 3:57:00 PM
tjcarst
I've given up. Disabling the HTTP Web Proxy Filter did not work either. I have a feeling this project will make it back on my project list someday soon. If anyone has any other ideas, they are appreciated.
tjcarst [ June 30, 2005, 03:57 PM: Message edited by: tjcarst ]
RE: Failed Connection Attempt - HTTP Status Code 13 - 6.Jul.2005 8:46:00 AM
netgoalie
Have you tried enabling SSL over port 80? (I'm not sure why your app. is trying to do SSL over 80 as opposed to 443, but that's what your log seems to indicate.) If this is a home-grown app., can you change it to use port 443? If not, try saving the following script to a .vbs file and running it:
set isa=CreateObject("FPC.Root") set tprange=isa.Arrays.GetContainingArray.ArrayPolicy.WebProxy.TunnelPortRanges set tmp=tprange.AddRange("SSL 80", 80, 80) tprange.Save
RE: Failed Connection Attempt - HTTP Status Code 13 - 13.Jul.2005 2:39:00 PM
tjcarst
I have not tried that yet.
RE: Failed Connection Attempt - HTTP Status Code 13 - 13.Jul.2005 4:34:00 PM
tjcarst
I can connect now that I enabled SSL on port 80. I still have some other errors, but I think they are specific to the third party connection software. I'll see if I can get them to assist now that I can connect.
Thanks for the suggestion. I had enabled tcp 80 to their site, but hadn't made it SSL.
tjcarst
RE: Failed Connection Attempt - HTTP Status Code 13 - 11.Oct.2005 6:15:00 AM
whatech
If you enable SSL over port 80, how does it affect those websites that uses 443?
I am having a similar problem accessing a citrix web application via proxy. Basically, when I log on to their website and click the application I need, it then downloads a file that is associated with the Citrix ICA Web client. The ICA Web client fires up a connection to a Citrix Metaframe server on TCP port 80. I have set an allow rule to the ip address range they have specified, but I am not able to access the application.
Can you please tell me, if I set SSL to port 80, does that mean we won't be able to access secure sites using SSL 443?
Also, according to the user guide of the website im trying to access, if using SOCKS & HTTPS Proxies, I need a dns/host entry for 'FTRL_PROXY' which corresponds to the ip address of their SOCKS.
Some help would be appreciated.
Thanks.
