Firewall Client Drops ater 10 minutes
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> Firewall Client Drops ater 10 minutes Page: [1] 2   next >   >>
Firewall Client Drops ater 10 minutes - 9.May2001 5:16:00 PM
SherwoodR
I have ISA server running so that SNat and Firewall Clients can connect to it. It works well for the most part.
I have users that Play on the Net. Since it is not a Business environment that is using ISA, the ports are open for them to connect to the game servers.
The game in particular is Half-Life.
The problem is that you can connect to the server fine and play fine. But after about 10 minutes the connection drops!
The server they are connected to is not down.
The ISA server is running fine.
The Gammer then has to Close the game and Restart it to get back on the server.
Same thing happens every time.
Any Ideas why it is doing this?
I am running an All Open Policy right now to see if that would help but it hasn't.
If you need more information or Details I wil be more than happy to share them with you.
Sherwood Robinson
Hostmaster
If at first it doesn't work reboot!'
If it still doesn't work slap the monitor!
If it still doesn't work after that kick the box.
If after all this it still doesn't work. Toss it out the window.
RE: Firewall Client Drops ater 10 minutes - 10.May2001 6:47:00 AM
Hi Sherwood,
When you say the connection drops, are you referring to a dial-up connection?
Do you see any errors in the Event log or in the ISA Management console?
Does the game support multiple players behind a NAT server?
Tom Shinder
Get it Here!
(in reply to SherwoodR)
RE: Firewall Client Drops ater 10 minutes - 11.May2001 9:25:00 PM
SherwoodR
No dailup it is a cable connection. No errors as far as I can tell its like ISA just forgets the connection is there. It is weird. Yes it does support multiple gamers.. from what I can tell but it is happening even when there is only one gamer on at a time
I will post more information tonight as I will have a chance to work on it some more
RE: Firewall Client Drops ater 10 minutes - 12.May2001 5:11:00 AM
SherwoodR
OK there are no errors poping up when this happens... and the local network still shows the traffic for the game but nothing is getting out! Very weird.. Works for awhile and just stops...
RE: Firewall Client Drops ater 10 minutes - 13.May2001 2:17:00 AM
Hi Sherwood,
Well, you've got me stumped! I am a total non-gamer, so I dont' have the skills or the resources to test this out. Hopefully some else on these boards will be able to lend some comfort
Tom Shinder
Get it Here!
RE: Firewall Client Drops ater 10 minutes - 16.May2001 6:18:00 AM
SherwoodR
yeah I am stumped also.. Think I may have to uninstall networking and start from scratch setting up All networking... This really is annoying. Ran CommView on the packets and I dont see any indication for the them to drop.. It really has me stumped! It trolls happily along and then starts losing packets and dies. Something wierd is going on...
RE: Firewall Client Drops ater 10 minutes - 17.May2001 4:49:00 AM
Hi Sherwood,
It could be something about the game itself. Do you play any other games? It would be interesting to see if the same thing happens with the other online games.
Tom Shinder
Get it Here!
RE: Firewall Client Drops ater 10 minutes - 17.May2001 2:52:00 PM
SherwoodR
Yes, I do play other games online. I will check into them this weekend and let you know. I have played this game over ICS and it works fine.
RE: Firewall Client Drops ater 10 minutes - 18.May2001 1:49:00 PM
felafel
Do you have RC1 of ISA? Did you upgrade from it?
If so, I would rebuild the box. I had issues with ISA even after applying SP1 but after rebuilding the box everything was cool.
When you are playing with multiple players do you force them to go out on different ports? I think you need to.
Could ISA be cacheing the connections? I find that I have to go to the main screen in HL and then back to the connection page to get into games at times. I don't get booted off though. weird. I have static IP and DSL.
RE: Firewall Client Drops ater 10 minutes - 18.May2001 3:06:00 PM
SherwoodR
My Server is running RC1 with the patches required to run ISA.
I have a static IP and Cable
Cache is not on on the server so It isn't caching the data.
I don't have trouble connecting to the server. most of the time. Some times when the game starts to render the Graphics it drops out and I reconnect just fine (this happened before ISA anyways). I actually use Gamespy to connect to the servers no problem. Just that 10 minutes in that it drops.
Hate to have to rebuild the ISA box as it is running Apache, Mail and several other services I need. But I think that is what I am going to do this weekend anyways.... I hate to have to do it but Oh Well....
Sherwood Robinson
Hostmaster
RE: Firewall Client Drops ater 10 minutes - 22.May2001 4:01:00 AM
SherwoodR
BAH! I resetup the server and got it configured enough that it would connect to the net with Firewall client.
I also tried a different game... Unreal Tournament works great.. Half-Life still crashes...
Next step... HL reinstall....
RE: Firewall Client Drops ater 10 minutes - 23.May2001 8:24:00 PM
Hi Sherwood,
Did you use this Protocol Definition for Half life?
Half Life Primary
> Port Number: 27015
> Protocol Type: UDP
> DirectionInfo: Send Receive
> Secondary Connection
> Port Range: 27015-27050
> Protocol Type:UDP
> DirectionInfo:Outbound
HTH<
Tom Shinder
Get It Here
RE: Firewall Client Drops ater 10 minutes - 24.May2001 2:53:00 PM
SherwoodR
Yup Sure did... First thing I made sure was in there before trying. I will however double check to make sure they are correct but I am quite sure they are...
Shouldn't be able to connect if they are not in there. Used the nice little link in the link section for the Game settings Microsoft ISA Server 2000
Game-Application Port Listing
thx
[This message has been edited by SherwoodR (edited 24 May 2001).]
RE: Firewall Client Drops ater 10 minutes - 24.May2001 8:41:00 PM
Hi Sherwood,
Then it remains a mystery. Keep working on it and please share any information you discover if you come up with a solution.
Tom Shinder
Get It Here
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 6:15:00 PM
mgoldie
Sherwood - any chance of some hints as to how you got Unreal Tournament working through ISA? I'm suffering frag withdrawl symptoms!
Many thanks,
Mark.
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 6:30:00 PM
SherwoodR
used the game settings link in the links section of the site. Worked great for me. But... Not using ISA anymore.. I gave up on getting Half-Life to work and got a new box that runs a linux firewall perfectly(not enought ump for W2kS and ISA). Demoted the W2kS Box to Workstation....
Got to use all those boxes you own you know... 8^)
The Link to Game Settings
Sherwood Robinson
Hostmaster
[This message has been edited by SherwoodR (edited 19 June 2001).]
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 9:43:00 PM
mgoldie
Cheers Sherwood. From the page u mentioned I've been able to set up HL and get it working...can't see UT on that page though...?
Mark.
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 9:48:00 PM
SherwoodR
try this one http://www.isaserver.org/ubb/Forum2/HTML/000142.html
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 9:50:00 PM
SherwoodR
Double posted sorry.. you can also do a search in general forums for Unreal and Half life. Lost of good information in there because this forums was not created yet.
Post #: 19
RE: Firewall Client Drops ater 10 minutes - 19.Jun.2001 9:55:00 PM
SherwoodR
Oh and funny thing is I still never got Half - Life to work beyond the 10 minutes or so...
Post in here if it works good for you.. I have it working no problem through a linux firewall so I am sure it is not my HL install that is messing things up.
Sherwood Robinson
Hostmaster
Post #: 20
