Firewall Client problems and questions
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Firewall Client problems and questions Page: [1]
Firewall Client problems and questions - 6.Jul.2006 8:41:26 PM
thecoffeeguy
Ok, so I was able to get the auto-detect issue corrected with the firewall client. However, I am having some issues as well as more questions.
1.) I am currently testing the FWC on four computers before i roll it out to the company. 3 of the 4 FWC will appear in the sessions filter when I start one up. ONe, for some reason is not. The only thing I can see is that the 3 that are working are running XP. The one that is not, is running 2000 pro. Also, when i look at the client icon by the clock, I don't see a 'up arrow' showing connection, BUT it is showing it is detecting the ISA Box.
2.) Since I am not using the FWC, on the 'Web Proxy -> Authentication ->, I currently have 'Require all users to authenticate' due to some web filtering software that we were testing. However, we are no longer testing the software (that is another thread entirely...bad bad experience). I just have 'integrated checked on the list, since we run AD the ISA is in AD.
3.) Firewall rules. What would be the best solution to use when specifying users? Should I just use groups that I have created within AD? Should I use 'all authenticated users'? What is ideal? What works best with the FWC, since that is the way we are going to be going?
4.) Any known issues with the FWC and Windows 2000?
5.) Do I need to run SP2 against the machines that have the FWC installed?
That should do it for now.
Thank you,
thecoffeeguy
RE: Firewall Client problems and questions - 10.Jul.2006 8:32:15 PM
thecoffeeguy
Any ideas on this one?
ANy idea why some FWClients don't show up when I run a filter session, looking for FWC connections?
(in reply to thecoffeeguy)
RE: Firewall Client problems and questions - 10.Jul.2006 9:04:31 PM
thecoffeeguy
Could their be a confliction between the FWC and the web proxy? Maybe the two are conflicting some how?
I'm confused and frustrated.
RE: Firewall Client problems and questions - 10.Jul.2006 9:10:21 PM
thecoffeeguy
Ok. Hopefully have some additional information that will help.
On the machines that are not showing up in the Firewall Client Session filter, I have noticed on those machines, when I 'hover' over the FWC icon by the clock, it says "Detected ISA Server." ON the machiens that do show up, it says connected.
So what would cause some computers to detect, but not connect?
Thx
RE: Firewall Client problems and questions - 10.Jul.2006 9:19:53 PM
Hi thecoffeeguy,
check out:
RE: Firewall Client problems and questions - 10.Jul.2006 9:23:52 PM
thecoffeeguy
ORIGINAL: spouseele
Hi thecoffeeguy,
check out:
Thanks.
I've read a lot of the above links, and they helped me solve the auto-detect issue I was having.
I can get the FWC's to autodetect, but connecting seems to be a problem.
Could be that the client was not installed while logged into the admininistrator account?
This is what is confusing me.
(in reply to spouseele)
RE: Firewall Client problems and questions - 10.Jul.2006 9:35:44 PM
Hi thecoffeeguy,
which autodetect method have you implemented: DHCP and/or DNS?
What does the Firewall Client Tool reports?
RE: Firewall Client problems and questions - 10.Jul.2006 9:53:41 PM
thecoffeeguy
ORIGINAL: spouseele
Hi thecoffeeguy,
Well, I actually have both in there: DNS and DHCP. Should I not do that?
Here is one that works:
C:\Documents and Settings\jwilliams.COURTESY\Desktop\fwcstuff>FwcTool.exe TestAutoDetect
FwcTool version 4.0.3439
Firewall Client for ISA Server 2004 support tool
Copyright (c) Microsoft Corporation. All rights reserved.
Action:         Test the auto detection mechanism
Type:           Default
Detection details:
   Timeout is set to 60 seconds
   Locating WSPAD URL in DHCP Server
   Locating option 252 in DHCP
   Reading network adapters information
   Option found on adapter:
   {19A59896-C0CD-4470-91E0-9084B125A4C5}
   DHCP option for WPAD found:
   http://isasrv04.mydomain.local:8080/wpad.dat
   WSPAD URL found in DHCP Server:
   http://isasrv04.mydomain.local:8080/wspad.dat
   Initializing Web server connection
   Resolving IP addresses for isasrv04.mydomain.local
   Resolved 1 address(es):
   192.168.100.1
   Connecting to address #1: 192.168.100.1:8080
   Waiting for address #1 to connect
   Address #1 successfully connected
   Requesting wspad.dat file
   Web server is connected and ready to send WSPAD file
   Downloading WSPAD file
   WSPAD file was downloaded successfully
   Detected ISA Server: isasrv04.mydomain.local:1745
Result:         The command completed successfully.
It is the same for both..both commands are completed succesfully.
They are detecting the ISA properly. Some are not 'connecting' though.
Any idea?
RE: Firewall Client problems and questions - 10.Jul.2006 11:06:01 PM
Hi thecoffeeguy,
are you saying that on *all* workstations the commands 'FwcTool TestAutoDetect /type:DHCP' and 'FwcTool TestAutoDetect /type:DNS' are working perfectly? So, may I assume you have used TCP port 80 for publishing the auto discovery information?
Assuming all the systems detect the ISA server well, how did you check they are not all connecting? Also, is there something common on all the systems that are not connecting?
< Message edited by spouseele -- 10.Jul.2006 11:08:55 PM >
RE: Firewall Client problems and questions - 10.Jul.2006 11:20:18 PM
thecoffeeguy
ORIGINAL: spouseele
Hi thecoffeeguy,
I only have the FWC on about 6 computers, mostly for testing. Two computers were working great. Always showing up. The other's were not. I could tell because I would start a filter for the FWC and then test the machine. They would not show up in the monitor.
On the few machines that i've run the FWC Tool on, yes, they all reported success.
Yes. Using port 80 for publish auto discovery.
To check, I would use the ISA monitor to watch for sessions. i would then walk over to the computer and look at the FWC in the tray. Just hovering over it with the mouse would say 'detected'. After browsing the internet, I would never see the green area pointing up and it would still say detected, but not connected (like on my PC for example, where it says 'connected')
Update: I was working on one of the computers and have some more information.
What I did was clear the IE settings of their LAN Connection settings. (unchecking automatically detect settings mostly).
Then, I would configure the FWC and detect ISA. Then, would go to web browser tab and hit 'configure'.
I would then open up IE and it would appear to work. Might take me a time or two to get it right, but that "seems" to have fixed it.
I'll post more after more testing.
RE: Firewall Client problems and questions - 10.Jul.2006 11:26:19 PM
Hi thecoffeeguy,
Aha... if IE or whatever browser is configured as Web Proxy client, that traffic will *not* be handled by the Firewall client. To understand why, check out http://blogs.isaserver.org/pouseele/2006/05/21/a-different-look-at-the-isa-clients/.
RE: Firewall Client problems and questions - 10.Jul.2006 11:29:16 PM
thecoffeeguy
ORIGINAL: spouseele
I was wondering if there was a confliction between the two. We used to push everyone through ISA as a proxy client. After having some issues and finding out all the benefits of FWC, we started testing.
With that, I should probably clear the GPO that automatically sets the settings in IE.
thx
RE: Firewall Client problems and questions - 10.Jul.2006 11:40:27 PM
Hi thecoffeeguy,
my favorite config for all the Windows based workstations is to configure them as Web Proxy *and* Firewall *and* SecureNAT client. To automate that process:
  • SecureNAT client: through DHCP.
  • Firewall Client: autodetect through the DNS method (optional DHCP).
  • Web Proxy client: let the Firewall client do that for you (see my article).
RE: Firewall Client problems and questions - 10.Jul.2006 11:47:29 PM
thecoffeeguy
ORIGINAL: spouseele
Hi thecoffeeguy,
That is almost what I am doing, right?
1.) SecureNAT: I do have DHCP setup with WPAD and my clients get IP via DHCP
2.) Firewall client: Have DNS and DHCP setup for WPAD. Soon to install FWC on all systems.
3.) On the FWC, just click web browser tab, configure. All done, right?
Lastly, when using the FWC, you want to make sure that in IE, there is nothing in the 'proxy server' section at the bottom, correct?
Thanks.
RE: Firewall Client problems and questions - 11.Jul.2006 12:19:31 AM
Hi thecoffeeguy,
almost there...
1. SecureNAT has nothing to do with WPAD!
2. I use DNS only, especially if I have to support older systems than WinXP-SP2 and Win2003-SP1.
3. that's not needed because you can define on ISA that the FWC should configure IE with a configuration script. That means that if the FWC detects the ISA server then FWC will reconfigure automatically IE for the configuration script.
From my article...
When you enable in Internet Explorer the options Automatically detect settings, Use automatic configuration script and Proxy server, then the processing order is as follows:
  • DHCP Option 252 (Automatically detect settings)
  • DNS WPAD Alias (Automatically detect settings)
  • Configuration script (Use automatic configuration script)
  • Manual configuration (Proxy server)
Note: the DHCP Option 252  is only supported for all users in Windows XP SP2 and Windows 2003 SP1 or later. The DNS WPAD Alias is supported for all users in Windows 2000 or later.
RE: Firewall Client problems and questions - 11.Jul.2006 12:30:57 AM
thecoffeeguy
ORIGINAL: spouseele
Hi thecoffeeguy,
almost there...
From my article...
Good stuff. Since I run both XP SP2 and Windows 2000 here, makes things more challenging.
Also, is it a good idea to put the FWC on servers as well? Is it needed?
Lastly, im assuming it is recommended to set in ISA under Firewall client:
-Automatically detect settings (well, ya. :) )
-Use automatic configuration script
----use default URL
I have those two checked right now, and NOT the 'Use a web proxy server' area.
Really appreciate the help Stefaan.
RE: Firewall Client problems and questions - 11.Jul.2006 12:24:36 PM
Hi thecoffeeguy,
No! The FWC is not designed for servers. So, servers should only be SecureNAT and Web Proxy clients.
----use default URL
In the Internal network properties, tab Firewall client I have:
  • Enable Firewall client support for this network checked.
  • Firewall client configuration: the FQDN of the ISA internal interface.
  • Web browser configuration on the Firewall client computer: only Use automatic configuration script checked. I populate the Use custom URL box with  http://FQDN:8080/array.dll?Get.Routing.Script but I believe you can check as well the Use default URL instead.
For the servers, leave IE at his default setting and that should be Automatically detect settings.
