Firewall Clients and URL Filtering
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Firewall Clients and URL Filtering Page: [1]
Firewall Clients and URL Filtering - 2.Mar.2008 4:17:42 AM
big_dazza
Hi. All my users are combination WP + FW clients. We push out their config via GPO. We also have WebMarshal running URL filtering.
If users manage to remove their IE proxy settings, then the FW client sends the IE traffic to ISA, but in the form of IP addresses instead of web addresses. If this happens they can access any site as it bypasses the WebMarshal filtering.
What possible way is there to stop this happening, bearing in mind GPO settings only apply periodically and users can keep removing their IE proxy settings?
RE: Firewall Clients and URL Filtering - 2.Mar.2008 9:30:57 AM
ferrix
If your web filter really can't understand requests unless they are in proxy form, that sounds like a bug in WebMarshal.
It wouldn't be hard to make another filter that fooled yours into seeing the URLs in the correct form, but it should not be necessary if their software works right.  Check with their support, I say.
(in reply to big_dazza)
RE: Firewall Clients and URL Filtering - 5.Mar.2008 9:38:25 PM
bboxron
Maybe these links will help you to solve your problem. It's about hostlogger. I tried it and since my firewall clients resolved hostnames and filtered urls.
http://forums.isaserver.org/m_2002040128/mpage_1/key_/tm.htm
http://www.elmajdal.net/ISAServer/HostLogger.aspx
(in reply to ferrix)
RE: Firewall Clients and URL Filtering - 9.Mar.2008 4:29:12 PM
Why not Remove the Connections Tab by using GPO ??
In this way, your users wont be able to change the proxy settings
