Forward SMTP to spamappliance
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> Forward SMTP to spamappliance Page: [1]
Forward SMTP to spamappliance - 28.Mar.2008 4:22:05 AM
himpe
I have a SBS2003 R2 premium installed on a customer site.
Up untill yesterday everything worked fine without ISA installed.
At the SBS2003 i forwarded port 25 in RRAS to the ip adres of the spamappliance (sonicwall ES200) wich then forwards all good mail to the SBS's exchange.
Yesterday i installed the ISA2004 including SP3.
I did my usual configuration and then published a new "mail server" (wich basically forwards port 25 trafic to the appliance again)
I also allow all outbound trafic.
Only now when i connect using telnet from outside the network i get the headers of the sonicwall appliance but i'm disconnected immediatly ( "connection to host lost" )
I have 2 similar setups at customer sites at the moment wich work fine.
Only difference is this site has R2 and ISA SP3 installed.
I allready logged what is happening in ISA and i see that the request is put through to the sonicwall but i only get an answer 20 secs later ...
If you have any suggestions please let me know.
RE: Forward SMTP to spamappliance - 28.Mar.2008 6:09:04 AM
himpe
This is my firewall policy
(in reply to himpe)
RE: Forward SMTP to spamappliance - 28.Mar.2008 10:33:47 AM
TitusHoc
What is with the access rule number 13? Do you have SMTP running on ISA? You can have a conflict on port 25 on ISA External interface
Can you run this command on ISA and share the result?
netstat –aon |find “:25”
Titus
(in reply to himpe)
RE: Forward SMTP to spamappliance - 31.Mar.2008 4:25:09 AM
himpe
ORIGINAL: TitusHoc
netstat –aon |find ":25”
Titus
Hi Titus,
thanks you for your response
The exchange is running on the SBS2003 aswell. So i'm routing trafic from the external interface to the sonicwall app then i forward good mail from the sonicwall to the isa internal interface wich is the exchange.
Here is the result from the netstat -aon | find ":25" command with the above rules !
So smtp redirect to sonicwall DISABLED
TCP    0.0.0.0:25             0.0
< Message edited by himpe -- 31.Mar.2008 6:01:38 AM >
(in reply to TitusHoc)
