H.323 Gatekeepers is disabled after installing ISA SP2
H.323 Gatekeepers is disabled after installing ISA SP2 - 18.May2005 9:58:00 PM
qsman
When I click on the gatekeeper server which is the name of the local machine (ISA) I get the error: Unable to access the gatekeeper server: You do not have sufficient permissions to access this gatekeeper server. Only members of the local administrators ... I never saw this before until I installed SP2. The H.323 Filter is enabled but I can't seem to figure out what is going on..Any help is appreciated. Sam [ May 19, 2005, 01:54 PM: Message edited by: qsman ]
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 19.May2005 4:11:00 PM
Rickymag
Good day,
My recommendation would be to make a backup of the machine then remove the Gatekeeper component and then read the component, this should reregister the object.
HTH
RM:)
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 19.May2005 4:58:00 PM
qsman
Thank you for your prompt response! I deleted the gatekeeper from the ISA mmc and added it again but that didn't work. How do you remove the gatekeeper component? I tried to change the ISA installation through the control panel but that does not list the gatekeeper. Thank you, Sam
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 19.May2005 5:09:00 PM
Rickymag
If you put the CD in and try to reinstall ISA you can then remove it and just the component part of it.
I know this is sometimes problematic HTH
RM
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 20.May2005 10:20:00 AM
qsman
Thank you, I will try that...
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 23.May2005 4:06:00 PM
qsman
FYI Removing the H.323 gatekeeper component and installing it back did not resolve the problem. I still have a a red disabled icon on the H.323 gatekeeper server.
Thank you,
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 28.May2005 3:32:00 PM
Rickymag
Please attempt an update to the very latest patches of the OS and ISA.
regards
RM
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 31.May2005 5:33:00 PM
qsman
I completed the os latest Microsoft software update. ISA has been previously updated with SP2 but that didn't fix the problem. The H.323 gatekeeper is still disabled! Thank you for all the help.
Sam
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 3.Jun.2005 7:36:00 PM
qsman
It is fixed. First of all I would like to thank RM for trying to help. However, installing new updates and stuff did not fix the problem. I finally figured out why the gatekeeper service is disabled and would like to share it with everyone. If you are running ISA on a 2003 server and you install 2003 SP1 you're H.323 is history. I removed SP1 and voila...I have worked with ISA 2000 for at least 3 years and was very close to reinstalling the OS and ISA but since 2K3 SP was one of the many changes I made. I had to give it a try and removing it. So here you go people ISA and 2K3 don't go together when it comes to H.323 protocol.
Sam
RE: H.323 Gatekeepers is disabled after installing ISA SP2 - 8.Jun.2005 2:42:00 AM
this is easily fixed, as I've done on a SBS2003 with SP1 and ISA2000:
Use the component services administrative tool, drill down until you get to DCOM config, then locate the GateKeeper H.323 entry.
Double-click it, switch to the security tab, then for each of the three sections, choose custom security, then add "Enterprise Admins" to the lists of allowed identities and with all permissions enabled.
all done!
