HTTPS To HTTPS Bridge With Custom Ports
All Forums >> [ISA 2006 Firewall] >> DMZ >> HTTPS To HTTPS Bridge With Custom Ports Page: [1]
HTTPS To HTTPS Bridge With Custom Ports - 19.May2009 6:51:13 AM
TokyoBrit
Is it possible to configure a firewall policy that would allow HTTPS to HTTPS bridging for web traffic, but using a different port for the perimeter?
Namely, HTTPS traffic comes into the perimeter via port, 8888 for example, is terminated at the ISA server, checked, then sent to the internal network over port 443? And to do this on a per site basis?
This way, internal users still use the regular URL (HTTPS://some.site.com/) but that communications with that sites web server are over a port other than 443.
Thanks in advance.
RE: HTTPS To HTTPS Bridge With Custom Ports - 19.May2009 10:14:41 AM
Yep, this is possible.
However, custom ports for SSL will cause problems for external users that are behind proxy servers or firewalls as they may only allow outbound "standard" SSL ports.
You will also need to consider link translation issues as you map between internal and external URLs.
What are you trying to achieve by using custom SSL ports? A quick port scan would reveal custom SSL ports very quickly, as would realising the port is hosting HTTPS traffic...
(in reply to TokyoBrit)
RE: HTTPS To HTTPS Bridge With Custom Ports - 19.May2009 8:17:58 PM
TokyoBrit
To put it simply, we have a new customer that would like us to use some form of web application to transfer files, but while they require HTTPS they don't use port 443.
To minimize the impact on the users involved with this customer, I would like them to use the regular URL, but have it translated to the customers port on the outside.
At worst case, I can just open the specific port on the external firewall application and create a firewall policy for that particular port.
RE: HTTPS To HTTPS Bridge With Custom Ports - 20.May2009 9:59:22 AM
Ah right, it should work then.
Configure the web listener to use the custom SSL port for HTTPS and configure SSL bridging to use 443 for the published server.
RE: HTTPS To HTTPS Bridge With Custom Ports - 21.May2009 12:31:03 AM
TokyoBrit
Thanks Jason. All done.
RE: HTTPS To HTTPS Bridge With Custom Ports - 21.May2009 4:37:55 AM
Cool
