Is it possible to have the HTTP redirector enabled for internal websites and at the same time authenticate users (user/group) through the web proxy? Thanks
Nope, sorry, that's not possible. The redirector will NOT pass credentials to the Web Proxy. So if you plan to use FW Clients and the HTTP Redirector you won't be able to access your internal web-sites.
Thanks, I'm having problem accessing on website that user need access to. When I try accessing the site through the Web Proxy it does not work, but it work when I access it with direct access settings. Is there any way to use the Web Proxy but redirect some websites not to use it? Thank You
Yes, users need to authenticate since we filter Internet access. The ISA server is on the same domain as the users are, if this is what you are asking. The pages that I'm having problems accessing reside on a different domain.
I think I found the problem, not %100 sure. It looks like they use port 82 for SSL (3.0). I did configure port 82 in the Protocol Definitions folder. I just installed Netscape and got the following message:
HTTP 502 Proxy Error - The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. (12204) Internet Security and Acceleration Server
# Click the Refresh button, or try again later. # Open the ssprod8.chase.com:82 home page, and then look for links to the information you want. # If you typed the page address in the Address bar, make sure that it is spelled correctly. # Verify that the Internet access policy on your network allows you to view this this page. # If you believe you should be able to view this directory or page, please contact the Web site administrator by using the e-mail address or phone number listed on the ssprod8.chase.com:82 home page.
