RSS |
Help!! Slow Login after intsalling ISA 2006
Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 6:23:41 AM
andrees
Hello, Can anyone help me with my problem. I have recently installed ISA 2006 on a Windows Server 2003 R2 64bit machine, and now everytime I try to log into Windows it takes a very long time to log in. When ISA is not installed it logs in fine. I thought it might be a DNS issue but my DNS settings are fine. Has anyone else experienced this problem before and if so can you help? Many Thanks S Andree
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 8:40:40 AM
have u installed ISA on a DC ?
_____________________________ Tarek Majdalani Windows Expert - IT Pro MVP Facebook : https://www.facebook.com/ElMajdal.Net
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:15:42 AM
andrees
Sorry, do you mean a Domain Controller? If so then the answer is no, it is installed on a separate server. Thanks
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:21:54 AM
Hi, have u installed ISA Server Supportability Update package http://support.microsoft.com/?kbid=939455 ? Whats is your NICs setting on both the client and ISA Server.
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:42:46 AM
andrees
Hello, Yes I have installed the ISA patch. My NIC settings are as follows. IP's are issued by DHCP from domain controller. Client: IP Address: 192.168.1.10 Subnet Mask: 255.255.255.0 Default Gateway: None ISA Server: Internal NIC: IP Address: 192.168.1.2 Subnet Mask: 255.255.255.0 Default Gateway: None Primary DNS: 192.168.1.1 Secondary DNS: 192.168.1.2 External NIC: IP Address: 172.0.1.1 Subnet Mask: 255.255.0.0 Default Gateway: 172.0.1.254 Primary DNS: 192.168.1.1 Secondary DNS: 172.0.1.254 Hope this helps. Thanks
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 11:06:02 AM
quote: Primary DNS: 192.168.1.1 Secondary DNS: 172.0.1.254 Never put any DNS Entry on the External NIC, only your Internal NIC should have a DNS Entry pointing your ur Internal DNS Server, and your Internal DNS Server should be able to forward external requests to your ISP DNS Servers. check this article : http://www.elmajdal.net/ISAServer/Internal_DNS_Forwarding.aspx
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 11:38:09 AM
andrees
Thanks for the advice, I have changed these settings, however the original problem is still occurring. Any other ideas would be appreciated? Thanks
RE: Help!! Slow Login after intsalling ISA 2006 - 27.Oct.2007 9:53:09 AM
andrees
Thanks for this, have installed the fix, however problem is still occuring. ANy more ideas? Thanks
RE: Help!! Slow Login after intsalling ISA 2006 - 10.Nov.2007 2:06:31 AM
Heinz
Andree ISA 2006 or any other version is not supported on 64bit!!! Try a block standard 32 bit win2003. Cheers, H
RE: Help!! Slow Login after intsalling ISA 2006 - 10.Nov.2007 2:08:30 AM
Heinz
Andree only hope you don't have a Dell 1950. I am having lots of fun with a box like this at the moment. Cheers, H
RE: Help!! Slow Login after intsalling ISA 2006 - 28.Oct.2009 7:41:41 AM
Ramy Kelany
Hi all Please I have the same problem, Is turning RSS off is the solutions? If yes, how can I do that?
New Messages
No New Messages
Hot Topic w/ New Messages
Hot Topic w/o New Messages
Locked w/ New Messages
Locked w/o New Messages
Post New Thread Reply to Message Post New Poll Submit Vote Delete My Own Post Delete My Own Thread Rate Posts
