How can i open a port in ISA 2006 for an Application that wana connect to outside sites??
All Forums >> [ISA 2006 Firewall] >> Access Policies >> How can i open a port in ISA 2006 for an Application that wana connect to outside sites?? Page: [1]
How can i open a port in ISA 2006 for an Application th... - 29.May2009 9:33:04 AM
itguyme
I have a scenario where A new library system applications need to access the outside sites on ports which are by default not open in ISA 2006.
Please tell me how to open those ports? how to create that policy ?
port 7090 is required to be open for a online library website. So shall I add protocols any ? or just enter the port(s) ?
RE: How can i open a port in ISA 2006 for an Applicatio... - 29.May2009 9:47:49 AM
inderjeet
You need to create a custom protocol depending the traffic is TCP or UDP. Then you need to add the protocol in your general internal access rule if you are not using the "All outbound Traffic"
Is that a web based application?
Inderjeet (MSFT)
(in reply to itguyme)
RE: How can i open a port in ISA 2006 for an Applicatio... - 29.May2009 10:02:20 AM
itguyme
yes actually its an online library
well the full url to which this port shud open is
telnet ****.loc.gov 7090
so should I add something in the policy also about this url ?
(in reply to inderjeet)
RE: How can i open a port in ISA 2006 for an Applicatio... - 29.May2009 10:19:36 AM
inderjeet
No Just mention the port number as per my previous post.
Does that use HTTP or HTTPS?
Inderjeet (MSFT)
RE: How can i open a port in ISA 2006 for an Applicatio... - 29.May2009 10:24:19 AM
itguyme
It uses http .....
RE: How can i open a port in ISA 2006 for an Applicatio... - 29.May2009 11:28:36 AM
inderjeet
Cool. If it was HTTPS then you would have needed to run the "ISA Tunnel Port Tool" listed at http://isatools.org/tools.asp?Context=ISA2006
Inderjeet (MSFT)
RE: How can i open a port in ISA 2006 for an Applicatio... - 30.May2009 3:18:48 AM
itguyme
thanx inderjeet,
it is working when i telnet the ipaddress of the url but it is still not working wen i telnet with the actual url and port ....is there any configuration problem ? why by IP and why not by name ?
RE: How can i open a port in ISA 2006 for an Applicatio... - 1.Jun.2009 8:54:52 AM
inderjeet
Are you able to get the name resolved from the machine you are tyring to open that website? If its working with IP not with name then Name Resolution is something i will focus my attention to.
Hows is your client configured to access internet? hwne you do NSLOOKUP on client machine are you able to resolve the website name?
Inderjeet (MSFT)
RE: How can i open a port in ISA 2006 for an Applicatio... - 1.Jun.2009 10:29:49 AM
itguyme
The www.loc.gov client application behind ISA 2006 is not opening.
I did add the ports 7090 and 210 required for the application in ISA2006 new policy .
I specified these ports as
TCP - Outbound 7090 and 7090
UDP - Send recieve 7090 - 7090
Also same for Port 210
But still the application is not connecting....
Client > ISA 2006 > ASA
RE: How can i open a port in ISA 2006 for an Applicatio... - 1.Jun.2009 11:54:21 AM
inderjeet
Have you opened the same on your ASA as well?
Inderjeet (MSFT)
RE: How can i open a port in ISA 2006 for an Applicatio... - 1.Jun.2009 12:10:03 PM
itguyme
Yea if we telnet form any NAT computer it telnets fine. But from behind any ISA 2006 comp it is not telneting ...
RE: How can i open a port in ISA 2006 for an Applicatio... - 1.Jun.2009 12:41:36 PM
inderjeet
 Better check it with Microsoft Support... Thats all i can tell as of now. Someone needs to remote into your ISA and check the config. I have no way of doing it
Inderjeet (MSFT)
RE: How can i open a port in ISA 2006 for an Applicatio... - 2.Jun.2009 1:57:03 AM
itguyme
I thank you for your willingness to support inderjeet.
I found the solution .
I installed firewall client and the application started running.
RE: How can i open a port in ISA 2006 for an Applicatio... - 3.Jun.2009 10:15:14 AM
inderjeet
That's cool...Sometimes the issues aren't at ISA atol :)
We kept checking in for the requests but now it make total sense that since the application was accessing the website from within itself, it was not a browser based request but a RPC request...which was to handled by Firewall client...
Good !!
Inderjeet (MSFT)
