How to Block Ping
All Forums >> [ISA Server 2004 Firewall] >> General >> How to Block Ping Page: [1]
How to Block Ping - 28.Jun.2008 1:23:36 PM
Combnet
I am running ISA 2004 and want to disable ping between clients. Currently I am using static IP for Client computer and dnt want them to be able to ping or communicate with each other. As most users on network are home users and have very poor passwords. I urgently need advice on how to disable it.
Many Thanks,
Zak
RE: How to Block Ping - 28.Jun.2008 2:59:29 PM
ISA Server ONLY controls what passes through it.
If your clients are all behind a single network interface behind ISA Server, then ISA Server can not control such issue.
(in reply to Combnet)
RE: How to Block Ping - 30.Jun.2008 2:56:17 AM
Combnet
Thanks for the help. But is there any other solution to stop that? I will really appreciate any advice.
Thanks & Best Regards,
Zak
(in reply to elmajdal)
RE: How to Block Ping - 30.Jun.2008 3:39:33 AM
omar.mardini
hi
by firewall of windows u can do it, when u open the firewall from control panel
the wizard of firewall appears ,go head to third tab (advancd) and there is icmp sitting ,so u can open it and uncheck of allow incoming echo reguest if u have enough permission
RE: How to Block Ping - 4.Jul.2008 8:48:43 AM
Combnet
Hi Omar thanks for the help. It works great. I also tried Ipsec that works great as well...
(in reply to omar.mardini)
