How to enable logging for dropped packets ?
All Forums >> [ISA Server 2004 Firewall] >> Logging and Reporting >> How to enable logging for dropped packets ? Page: [1]
How to enable logging for dropped packets ? - 20.Apr.2004 2:45:00 PM
penrose.l@2college.nl
ISA Server detected a spoof attack from Internet Protocol (IP) address 172.16.1.3. A spoof attack occurs when an IP address that is not reachable via the interface on which the packet was received. If logging for dropped packets is set, you can view details in the packet filter log.
Since I expect this result to come from our NLB setup , I want to disable spoof detection for certain IP Addresses ( 172.16.1.0/24 ) but I can't seem to find an option to set the logging for dropped packets ?
<maybe I'm getting blind...>
Kind regards,
Lex P.
RE: How to enable logging for dropped packets ? - 21.Apr.2004 1:24:00 PM
Hi Lex,
There was a mechanism to do this in ISA 2000, have you tried that one? Don't know if it would work, but its worth a try.
Why do you think this is expected with NLB? I've run ISA 2000 with NLB and didn't see spoofs.
(in reply to penrose.l@2college.nl)
RE: How to enable logging for dropped packets ? - 22.Apr.2004 9:43:00 PM
Hi Tom ,
with 2 NLB nodes we didn't find any problems.
However , more than 3 NLB nodes in a cluster will start reporting these errors.
We use Rainwall ( eval ) and it's really a nice product but it uses a NIC to sync it's data over ( 172.16.x.x in our case ). Somehow the other nics ALSO report over this nic. This gives the spoof errors.
btw : I tried adding the DWORD key 'SpoofDetection' and set it to 0 but it didn't work. I guessed they changed it [Smile] )
Kind regards,
Lex P.
RE: How to enable logging for dropped packets ? - 22.Apr.2004 11:54:00 PM
Hi Lex,
Thanks for the info. I'm still trying to find out how to block the spoof errors. I let you know when I find out.
RE: How to enable logging for dropped packets ? - 14.May2004 10:05:00 AM
Hi Tom ,
Ok we found a way to enable logging for dropped packets. It appears we have been using a wrong build of ISA 2004 Beta 2 all the time.
In the ISA 2004 RC version which we have acquired there's a simple option to turn logging on for dropped packets exactly where you'd expect it.
So the solution is to wait for the ISA 2004 final version [Smile] )
Kind regards,
Lex P.
RE: How to enable logging for dropped packets ? - 16.May2004 6:15:00 PM
Hi Lex,
Very good! Thanks for the update!
