How to make web Proxy client
All Forums >> [ISA Server 2004 Cache] >> Web Proxy client >> How to make web Proxy client Page: [1]
How to make web Proxy client - 24.Feb.2008 2:00:16 AM
mypass604
hi
            I need complete guidance that how can i make "Web Proxy clients" iam using windows xp
thanks in advance
RE: How to make web Proxy client - 24.Feb.2008 2:57:53 AM
Start with this article : http://www.isaserver.org/tutorials/Configuring-WPAD-Support-ISA-Firewall-Web-Proxy-Firewall-Clients.html
(in reply to mypass604)
RE: How to make web Proxy client - 24.Feb.2008 6:08:40 AM
mypass604
thanks for the URL. I want to  configure WEB Proxy and Firewall in my client  windows xp machine.For testing purpose i install ISA Server 2004 and one client machine.
I have successfully test Scure NAT in my lab.Now i want to learn how to configure Web proxy and ISA firewall in my client machine.
The above website is complecated to me to understand because DNS ,and WAN IP all are already configured in my DSL routrer. I just gave LAN IP (Class C Scheme)
Thnaks in advance.
(in reply to elmajdal)
RE: How to make web Proxy client - 24.Feb.2008 8:49:19 AM
mm i smell something wrong here !!
how many NIC there is on your ISA Server and how did you set them ?
IP/DG/DNS ..... ?
RE: How to make web Proxy client - 24.Feb.2008 12:00:33 PM
mypass604
Well i have two NIC cards.
WAN
LAN
In wan i gave manual IP address and DNS also
in ISA LAN i give
IP:  192.168.1.55
Subnet: 255.255.255.0
Default Gateway:192.168.5.233
DNS:           135.12.40.5
Alternate:      135.13.40.6
Client IP
10.0.0.2
255.255.255.0
10.0.0.1
DNS:         135.12.40.5
With SecureNAT  it works fine now i want to configure
Web Proxy Client
Fire Wall Client
thanks
RE: How to make web Proxy client - 25.Feb.2008 1:44:16 AM
mypass604
hi
   if i use the ISA LAN IP i.e(10.0.0.1) in IE----->connections----->Lan Settings
and under "Proxy Server"  i may give the IP with port 8080 then i think it will work?
RE: How to make web Proxy client - 25.Feb.2008 4:07:22 AM
WAN
LAN
in ISA LAN i give
IP:  192.168.1.55
DNS:           135.12.40.5
Wrong, on the External NIC, never put any DNS Entry.
more info here : http://www.isaserver.org/tutorials/Configuring_ISA_Server_Interface_Settings.html
Seems like you dont have an Internal DNS !!! is that why u r putting your ISP DNS on your CLient NIC ??
now for the web proxy clients, in its simplest forms, you have to enable web proxy inside the Internal Network LAN Properties, on ISA Server.
and in the CLient IE > Tools > Internet Options > Connection > LAN  > Proxy Settings and insert your ISA Server Internal IP and proxy port .
Tarek
RE: How to make web Proxy client - 25.Feb.2008 10:06:18 AM
mypass604
thanks for your help.I want to attach my ISA settings,LAN  settings and proxy settings  pictures.when i click on Add Image it switch to URL . How can i upload it to show you by snaps .It will be easy for you to see where iam doing mistake.
thanks.
RE: How to make web Proxy client - 25.Feb.2008 12:20:48 PM
u need to host you image somewhere, try google and write image upload, you find plenty of free image hosting sites.
RE: How to make web Proxy client - 29.Feb.2008 10:17:32 AM
mypass604
Well i did the solution of my problem. I add the client  computer (LAN IP Address)  in ISA Firewall policy then give the same address in IE Proxy settings.
My browsing is now working on my client computer as well as  yahoo messenger also.
Now please guide me that actually what is web  proxy client? it is taking all the web pages the ISA Server .The SecureNat Client was also taking from ISA Server.Only difference i feel in Secure NAT i gave DNS Address also but in web proxy client i deos't give in its LAN Address. what you say about it.
Thnaks.
RE: How to make web Proxy client - 29.Feb.2008 5:31:09 PM
read this :
  • The SecureNET (SecureNAT) client A SecureNET client is a machine configured with a default gateway address that allows Internet bound requests to pass through the ISA Firewall. If the SecureNET client is located on the same subnet of the ISA Firewall, then the default gateway address will be IP address of the ISA Firewall’s interface on the same network ID as the client. If the clients are on a remote subnet from the ISA Firewall, then the IP address will be a router interface address that will use route outbound requests through the ISA Firewall. While the “official” name in the ISA Firewall documentation is SecureNAT client, it is more accurately referred to as a SecureNET client because the Network Rule defining the connection between a source and destination network does not have to be a NAT relationship, it could be a Route relationship.
  • The Firewall Client The Firewall client is a piece of software that must be installed on the client operating systems (the Firewall client should not be installed on server operating systems and never on the ISA Firewall itself). The Firewall client is a generic Winsock proxy client that intercepts Winsock application network calls and forwards them (remotes them) directly to the ISA Firewall. This enables the Firewall client to be transparent to the network routing infrastructure and does not depend on default gateway or route of last resort configuration on network routers. The only network infrastructure requirement is that the clients have a route to the IP address of the ISA Firewall closest to the client. The Firewall client also enables user authentication for access control and supports secondary connections for complex protocols when there is no Application Filter to provide that support. In contrast, SecureNET clients must have an Application Filter in place to support complex protocols that may require multiple primary and secondary connections.
  • The Web Proxy client The Web proxy client is a machine that has its browser configured to use the ISA Firewall as its Web proxy device. Browser configuration can be done manually, or can be automated using the WPAD protocol and WPAD entries in DHCP and/or DNS. The Web proxy client configuration supports only HTTP, HTTPS, and HTTP tunneled FTP requests and does not support FTP upload, only FTP download. Web proxy clients can authenticate with the ISA Firewall, in contrast to SecureNET clients, which cannot authenticate with the ISA Firewall.
  • source : http://www.isaserver.org/tutorials/Definitive-Guide-ISA-Firewall-Outbound-DNS-Scenarios-Part2.html
    RE: How to make web Proxy client - 1.Mar.2008 11:16:01 PM
    mypass604
    Thanks "elmajdal"  for the help . well there is a question that as i mentioned i added my client computer in ISA Server 2004 then my proxy client worked by adding ISA LAN IP Adress i.e 10.0.0.1 in the internet explorer. (
    2-Now if there are 100 computers then should i add all 100 computers in ISA Firewall policy (In case of workgroup)
    3- if the computers are member of domain than what is the method to use Web Proxy Client? (In case of member of Domain).
    thanks again
    mypass604
