IE LAN Settings
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> IE LAN Settings Page: [1]
IE LAN Settings - 5.Jan.2006 7:44:40 PM
kdiekemper
My internal users are using ISA Firewall Client to access the internet through a ISA Server 2000.
When IE LAN Settings has  "Automatically detect settings" enabled they access the internet throught the ISA Server 2000 Firewall. When "Use a proxy server for you LAN" is enabled along with the ISA Server 2000 UNC name and port 9876 settings there is access to the internet without ISA Firewall restriction.
Is there a document that explains the use of the IE LAN settings when used with ISA Firewall Client?
What causes the Proxy setting the bypass the ISA Server Firewall?
Ken
RE: IE LAN Settings - 6.Jan.2006 3:51:54 PM
Hi Ken,
if the ISA server is your only exit point to the Internet then all traffic should be filtered by the ISA server, regardless how the client is configured. So, can you give us some more exact info about your configuration? A good starting point could be:
- ipconfig /all on ISA
- route print on ISA
- content of the LAT on ISA
- ipconfig /all on an internal workstation
(in reply to kdiekemper)
RE: IE LAN Settings - 9.Jan.2006 2:52:35 PM
kdiekemper
Hello Stefaan
Thanks for the replay to my question.
My ISA server is the only exit point to the Internet.
The ISA server is on a multi segment network with users from all different segments.
I am using the ISA Firewall client on all user work stations because of that.
Below is the information you requested.
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>ipconfig /all
Windows 2000 IP Configuration
       Host Name . . . . . . . . . . . . : proxy1
       Primary DNS Suffix  . . . . . . . : Proxy1
       Node Type . . . . . . . . . . . . : Hybrid
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
       DNS Suffix Search List. . . . . . : Proxy1
Ethernet adapter External Adapter:
       Connection-specific DNS Suffix  . :
       Description . . . . . . . . . . . : Broadcom Gigabit Ethernet Controller
       Physical Address. . . . . . . . . : 00-06-5B-39-0E-61
       IP Address. . . . . . . . . . . . : 10.255.3.1
       Default Gateway . . . . . . . . . : 10.255.3.2
       DNS Servers . . . . . . . . . . . : 206.166.83.20
                                           206.166.61.21
                                           206.166.57.20
       NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Internal Adapter:
       Description . . . . . . . . . . . : Intel 8255x-based PCI Ethernet Adapt
er (10/100)
       Physical Address. . . . . . . . . : 00-06-5B-39-0E-60
       IP Address. . . . . . . . . . . . : 10.0.1.1
       Subnet Mask . . . . . . . . . . . : 255.255.0.0
       DNS Servers . . . . . . . . . . . : 10.3.1.8
                                           10.3.1.9
C:\>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x1000003 ...00 06 5b 39 0e 60 ...... Intel 8255x-based Integrated Fast Ethernet
0x1000004 ...00 06 5b 39 0e 61 ...... Gigabit Ethernet Driver
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
         0.0.0.0          0.0.0.0       10.255.3.2      10.255.3.1       1
        10.0.0.0      255.255.0.0         10.0.1.1        10.0.1.1       1
        10.0.1.1  255.255.255.255        127.0.0.1       127.0.0.1       1
        10.1.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.2.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.3.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.4.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.5.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.6.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.7.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.8.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
        10.9.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.10.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.11.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.14.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.17.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.20.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.21.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.23.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
       10.24.0.0      255.255.0.0       10.0.1.254        10.0.1.1       1
      10.255.3.0    255.255.255.0       10.255.3.1      10.255.3.1       1
      10.255.3.1  255.255.255.255        127.0.0.1       127.0.0.1       1
  10.255.255.255  255.255.255.255         10.0.1.1        10.0.1.1       1
  10.255.255.255  255.255.255.255       10.255.3.1      10.255.3.1       1
       127.0.0.0        255.0.0.0        127.0.0.1       127.0.0.1       1
       224.0.0.0        224.0.0.0         10.0.1.1        10.0.1.1       1
       224.0.0.0        224.0.0.0       10.255.3.1      10.255.3.1       1
255.255.255.255  255.255.255.255         10.0.1.1        10.0.1.1       1
Default Gateway:        10.255.3.2
Persistent Routes:
Network Address          Netmask  Gateway Address  Metric
LAT has the following settings
10.0.0.0              10.254.255.255
150.150.10.218    150.150.10.218
192.168.0.0         192.168.1.255
(in reply to spouseele)
RE: IE LAN Settings - 10.Jan.2006 9:20:52 PM
Hi Ken,
here are some questions/remarks on your config:
1. Is your OS and ISA fully patched?
2. I would remove the DNS server settings on he ISA External adapter. Of course, make sure you have configured forwarders on your internal DNS servers. That should optimize your DNS resolving.
3. According to the ISA's routing table the LAT should only contain the entry '10.0.0.0 - 10.24.255.255'. So, what are the other entries doing there?
4. To what does the ISA Server 2000 UNC name resolves?
