IPSEC and Static mapping!
All Forums >> [ISA Server 2000 Misc.] >> ISA Server Wish List >> IPSEC and Static mapping! Page: [1]
IPSEC and Static mapping! - 17.Oct.2002 11:42:00 PM
thejun
I want IPSEC to work!
I want Static mapping!
Then ISA Server will be complete
RE: IPSEC and Static mapping! - 18.Oct.2002 12:56:00 AM
Hi thejun,
everybody wants IPSec to work! However, the IPSec protocol was *not* designed with NAT in mind because it was originally designed for the IPV6 world.
Because the real world still use IPV4 and NAT is nowadays a requirement due to the shortage of public IPV4 addresses, the IETF was obliged to do something about that real life problem. It has taken them a lot of time to agree on a solution, but at last we may expect that the current drafts will soon become a standard, probably by the end of the year.
So, IPSec passthrough is *not* an ISA specific problem. If you want to learn more about this issue, check out:
- http://www.ietf.org/internet-drafts/draft-ietf-ipsec-nat-reqts-02.txt
- http://www.ietf.org/internet-drafts/draft-ietf-ipsec-nat-t-ike-03.txt
- http://www.ietf.org/internet-drafts/draft-ietf-ipsec-udp-encaps-03.txt
- http://www.microsoft.com/vpn
- http://www.microsoft.com/windows2000/technologies/communications/ipsec/redir-cableguytraversal.asp
(in reply to thejun)
RE: IPSEC and Static mapping! - 18.Jan.2003 7:51:00 AM
hughman
sorry stefaan but i dont understand your post.
plenty of other firewalling solutions support ipsec passthrough (IPCop and Smoothwall to name 2), i cannot see why isa doesnt do this....
RE: IPSEC and Static mapping! - 18.Jan.2003 4:35:00 PM
Hi hughman,
ISA is always doing N:1 NAT or PAT and this breaks 'plain' IPSec. The only way to get IPSec through ISA is if the IPSec implementation supports the IPSec NAT Traversal drafts as specified by the IETF. This is an IPSec design problem and *not* an ISA problem. Check out http://www.ietf.org/html.charters/ipsec-charter.html for the status of the latest drafts.
I know that some other firewalls *partial* support IPSec passthrough. But that doesn't solve the real problem! [Razz] So, I'm convinced that Microsoft has taken the good decision *not* to implement those dirty hacks. However, it is a pity that the NAT Traversal is still not available in W2K.
RE: IPSEC and Static mapping! - 25.Mar.2003 3:32:00 PM
Bruce Lee
However, NAT is possible when IPSec uses the Tunnel Mode. In this mode all IPsec packets are tunnelled within a HTTP header... This header can be modified while transporting the IPsec header, because the integrity and authetnicating is done with data inside the IPsec header...
RE: IPSEC and Static mapping! - 25.Mar.2003 8:57:00 PM
Hi Bruce,
are you sure about your statement? In which IETF RFC or draft have your read that? As far as I know IPSec and HTTP has nothing to do with each other.
RE: IPSEC and Static mapping! - 26.Mar.2003 12:44:00 AM
thejun
Me Too!
When I vpn into a Cisco Firewall using cisco client, They always have it set up for IPSEC.
This is what a cisco tech told me when I asked to let me in while using ISA
"I looked at the packets and saw that Ipsec, as I stated earlier was working on protocol 50. I made it encapsulate into TCP and UDP packets so that users who are behind a firewall coming as a PAT ip with unique port numbers terminate the session here."
Whatever that means...
RE: IPSEC and Static mapping! - 26.Mar.2003 5:57:00 PM
Hi thejun,
the IETF proposed method to make IPSec NAPT compliant is UDP encapsulating the IPSec ESP packets. Check out the IETF website for more info.
Here is the latest info (56the IETF meeting March 2003) for the NAT Traversal drafts:
- draft-ietf-ipsec-udp-encaps-06.txt: ready for IETF last call for proposed standard
- draft-ietf-ipsec-nat-t-ike-05.txt: ready for IETF last call for proposed standard
- draft-ietf-ipsec-nat-reqts-04.txt ready for IETF last call for informational RFC
BTW --- the Cisco TCP encapsulation is Cisco proprietary. Moreover, according to http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=13;t=001170 it will NOT work through ISA server.
