IPSec VPN and IP Spoofing / routing problem
All Forums >> [ISA Server 2004 Firewall] >> VPN >> IPSec VPN and IP Spoofing / routing problem Page: [1]
IPSec VPN and IP Spoofing / routing problem - 26.May2008 5:36:53 PM
itmanager
Hi all,
I am implementing an IPSec tunnel with partners who run a Cisco at their end.
We can establish both phases of the tunnel and my counterpart can trace a path back to a target host at my end.
But something is preventing me from tracing a path to the partner end. When I attempt a ping or Tracert I can see (in IPSec Mon) the Phase II connection become established. But nothing gets returned.
Clearly a routing problem but where/how?
Can anyone point out where the problem should lie?
Kevin
Some details:
In ISA Monitoring (logging) I can see that the ping packet is being dropped;
Log type: Firewall service
Status: A packet was dropped because ISA Server determined that the source IP address is spoofed.
Rule: -
Source: Internal (10.201.1.42:8)
Destination: B2B VPN (172.17.97.1:0)
Protocol: Ping
User: -
Additional information
·         Number of bytes sent: 0 Number of bytes received: 0
·         Processing time: 0ms Original Client IP: 10.201.1.42
·         Client agent: -
I have actually turned IP Spoofing detection off (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Fweng\Parameters\DisableSpoofDetection=1).
Configuration (actual addresses changed but still relative to each other);
ISA 2004 SP2
4 interfaces;
External               110.155.245.146 but also with multiple IPs on the external interface
DMZ1                    172.16.1.0 /24
DMZ2                    210.100.100.240 /28
DMZ3                    10.201.1.0 /24
The VPN encryption network
                172.17.96.0 /20
ISA Networks
                There is a network object creating the VPN IPsec tunnel which is working
ISA Network Rules
                There is a network rule that Routes between the VPN network and the DMZ3 network
ISA Firewall Policy
There are 2 rules (In and Out) allowing traffic between VPN network and DMZ 3 network (currently All Outbound traffic until issue is resolved).
The local Tunnel Endpoint is 110.155.249.187
Active Routes:
Destination           Netmask                  Gateway                          Interface                             Metric
0.0.0.0                    0.0.0.0                     110.155.245.145           110.155.245.146                20
10.201.1.0             255.255.255.0       10.201.1.1                       10.201.1.1                            10
10.201.1.1             255.255.255.255   127.0.0.1                         127.0.0.1                              10
10.201.1.111        255.255.255.255   127.0.0.1                         127.0.0.1                              50
10.201.20.0           255.255.255.0       10.201.1.100                   10.201.1.1                            1
10.201.30.0           255.255.255.0       10.201.1.100                   10.201.1.1                            1
10.201.40.0           255.255.255.0       10.201.1.100                   10.201.1.1                            1
10.255.255.255    255.255.255.255   10.201.1.1                       10.201.1.1                            10
127.0.0.0                255.0.0.0                 127.0.0.1                         127.0.0.1                              1
172.16.1.0              255.255.255.0       172.16.1.1                       172.16.1.1                            10
172.16.1.1              255.255.255.255   127.0.0.1                        127.0.0.1                              10
172.16.255.255    255.255.255.255   172.16.1.1                       172.16.1.1                            10
110.155.245.0      255.255.255.0        110.155.245.146           110.155.245.146                20
110.155.245.146  255.255.255.255   127.0.0.1                         127.0.0.1                              20
110.155.245.255  255.255.255.255   110.155.245.146           110.155.245.146                20
110.155.249.176  255.255.255.240   110.155.249.189           110.155.245.146                20
110.155.249.187  255.255.255.255   127.0.0.1                         127.0.0.1                              20
110.155.249.188  255.255.255.255   127.0.0.1                         127.0.0.1                              20
110.155.249.189  255.255.255.255   127.0.0.1                         127.0.0.1                              20
110.155.249.190  255.255.255.255   127.0.0.1                         127.0.0.1                              20
110.155.249.255  255.255.255.255   110.155.245.146            110.155.245.146                20
110.155.251.240  255.255.255.240   110.155.251.241            110.155.251.241                30
110.155.251.241  255.255.255.255   127.0.0.1                         127.0.0.1                              30
110.155.251.255  255.255.255.255   110.155.251.241           110.155.251.241                30
224.0.0.0                  240.0.0.0               10.201.1.1                       10.201.1.1                            10
224.0.0.0                  240.0.0.0               172.16.1.1                       172.16.1.1                            10
224.0.0.0                  240.0.0.0               110.155.245.146           110.155.245.146                20
224.0.0.0                  240.0.0.0               110.155.251.241           110.155.251.241                30
255.255.255.255  255.255.255.255   10.201.1.1                       10.201.1.1                            1
255.255.255.255  255.255.255.255   172.16.1.1                       172.16.1.1                            1
255.255.255.255  255.255.255.255   110.155.245.146             110.155.245.146                1
255.255.255.255  255.255.255.255   110.155.251.241             110.155.251.241                1
Default Gateway:    110.155.245.145
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
