ISA2004 and Active Directory
ISA2004 and Active Directory - 10.Jun.2004 10:25:00 AM
face_offir
hi i install w2k3 and active directory my client can join and logon to my server after i install isa2004 my clint can't login to domain how can i do?
RE: ISA2004 and Active Directory - 11.Jun.2004 4:51:00 AM
Hi Face,
Is the ISA firewall installed on the domainc controller?
Thanks! Tom
RE: ISA2004 and Active Directory - 12.Jun.2004 11:33:00 AM
face_offir
Hi Tom yes , ISA 2004 installed on my domain controller and i add a rule to open all outbound outgounig but my client can't connect to domain
RE: ISA2004 and Active Directory - 12.Jun.2004 12:54:00 PM
Hi Face,
You should move the domain controller off the Firewall, since this configuration hasn't been described yet. Firewalls should not be domain controllers.
HTH, Tom
RE: ISA2004 and Active Directory - 13.Jun.2004 3:45:00 PM
face_offir
Hi Tom i don't have any problem with w2k3 server and active drirectory that ISA Server2000 but with ISA2004 my client can't join or logon to domain
RE: ISA2004 and Active Directory - 13.Jun.2004 7:34:00 PM
Hi Face,
So, the ISA firewall is not a domain controller?
The problem is the clients cannot contact another machine on the network that is a domain controller?
If so, make sure the local domain table is configured correctly and that the Internal network addresses are also configured correctly.
HTH, Tom
RE: ISA2004 and Active Directory - 15.Jun.2004 8:35:00 AM
face_offir
Hi Tom 1- w2k -> AD -> ISA2000 (all outgouing is allowed) 2-w2k3 -> AD -> ISA2004 (all outgouing is allowed) in ISA2004 my client can't join or logon to my domain but in ISA 2000 clint work without any problem tanx Tom
RE: ISA2004 and Active Directory - 16.Jun.2004 1:08:00 AM
Hi Face,
I'm not clear on what machine can't join the domain. Is it the ISA firewall machine itself that cannot join the domain? Or is it an internal network host that can't join the domain?
Thanks! Tom
RE: ISA2004 and Active Directory - 16.Jun.2004 8:06:00 AM
face_offir
Hi Tom 1-first i installed w2k3 and AD my workstation join and logon to my domain after i installed ISA2004 my workstation can't join or logon to my domain but 2-i installed w2k3 and AD my workstation join and logon to my domain after i installed ISA2000 my dont't have any problem to join or logon to my domain tanx Tom
RE: ISA2004 and Active Directory - 16.Jun.2004 4:15:00 PM
SolidworK
face, you're being a bit confusing....
Is your ISA Server also your DOMAIN CONTROLLER? If it is, this is not supported nor is it recommended... whether or not it works in ISA 2000 is a moot point.
This is the equivilent of having the president sitting on top of a tank in the middle of a war. Why have your greatest assets sitting on top of your armour? BAD idea.
RE: ISA2004 and Active Directory - 16.Jun.2004 8:02:00 PM
Hi SolidworK,
Ha! Great analogy!
Thanks! Tom
RE: ISA2004 and Active Directory - 26.Jun.2004 10:58:00 PM
Hi panikovski,
ISA 2004 firewalls are true network firewalls in the same class as Checkpoint, Bluecoat and Astaro. (PIX is mostly a packet filtering router, so I don't really put it in the true network firewall stateful application layer inspection class).
So, I would not expect to put the ISA firewall on a DC any more than I would put a DC on a Checkpoint, Bluecoat or Astaro device.
However, the SBS community may be working on solutions for this. You might check out SBS related sites.
HTH, Tom
RE: ISA2004 and Active Directory - 27.Jun.2004 11:30:00 AM
panikovski
HTH, Tom
Thanks for your answer! Well, i checked some SBS community, and there is no any solution yet for this. Just some post about to open all rules at internal interface.
Post from ms: URL
RE: ISA2004 and Active Directory - 27.Jun.2004 6:58:00 PM
Hi panikovski,
Looks like they haven't got it figured out yet. I'm sure once they do, they'll put up a procedure on one of the SBS Web sites. My focus is on ISA 2004 as a firewall, but I'll always welcome submissions from authors who have expertise in SBS installs.
HTH, Tom
RE: ISA2004 and Active Directory - 17.Jul.2004 9:26:00 PM
LoginKat
Just my 2 cents worth - if you aren't publishing any RPC services to the net then you'll find that ISA 2004 runs silky smooth on a Domain Controller after you disable the RPC Filter in the Add-Ins section.
I'm one of those tight budget folks who runs her Exchange Server, SQL Server, IIS6, and anything else I can think of together on the same box as ISA.
Works great!
RE: ISA2004 and Active Directory - 19.Jul.2004 2:03:00 PM
panikovski
quote: Originally posted by ISAKat: ...after you disable the RPC Filter in the Add-Ins section.
Just disable RPC filter? Is it working? Well going to test!...
RE: ISA2004 and Active Directory - 19.Jul.2004 4:32:00 PM
leslie
Fascinating discussion. I was wondering if someone could give me concrete advice. I have a separate Domain controller now but used to run isa on the same machine without any problems. I face all sorts of problems when I want to use Windows groups and users on my ISA server unless i make it an Additional Domain controller. How do i set this up? What is the best config for me? I have separate servers to play around with
RE: ISA2004 and Active Directory - 19.Jul.2004 8:44:00 PM
quote: Originally posted by ISAKat: Just my 2 cents worth - if you aren't publishing any RPC services to the net then you'll find that ISA 2004 runs silky smooth on a Domain Controller after you disable the RPC Filter in the Add-Ins section.
Works great!
Hi ISAKat,
Yikes! The RPC filter is one of the most important application layer filters on the firewall. I would not be comfortable using it without the filter enabled.
Thanks! Tom
RE: ISA2004 and Active Directory - 20.Jul.2004 6:08:00 PM
panikovski
! If you understand the security risk of having DC and ISA on the same machine then:
Make a "Allow All" rule from your "internal network" to the "Local Host"... (don't disable RPC filter!)
Its works. [ July 20, 2004, 06:12 PM: Message edited by: panikovski ]
