ISA2004 in existing PIX environment: connectivity issues
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> ISA2004 in existing PIX environment: connectivity issues Page: [1] 2   next >   >>
ISA2004 in existing PIX environment: connectivity issues - 27.Jun.2006 2:20:00 PM
redlob
Hi guys,
I'm trying to implement an ISA2004 server into an existing environment. In this network, there is a PIX-PIX vpn in place, connecting the 2 offices. I want to create an extra subnet with ISA, in which the mail server will be installed. Everything is in place, but I am not able to ping from the DMZ to the server on the other end of the VPN. I created access rules in ISA and the PIX'es which would allow all traffic, but the ping never gets a response...
Here's a picture of the current situation:
I am not sure if this is an ISA/PIX/Routing problem, so I provided as much details as possible. I'm struggeling with this for 3 days now, I think I broke the worldrecord google searching... Any help is very much appreciated !!
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 8:28:22 AM
redlob
No suggestions at all ?
(in reply to redlob)
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:03:17 AM
MSchaefer
Redlob,
Do you have a route configured to and from the 192.168.4.0 subnet?  You could test it by doing a >route print on the 192.168.3.2 computer.  You could also add a route on the 192.168.3.2 computer directly by this entering this at the command promt
>"route ADD 192.168.4.0  MASK 255.255.255.0 192.168.3.254"
Just take the quotes out.  It does not look like you have a route built into your PIX 506E right now.
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:20:15 AM
redlob
Hi Mark,
I've added the route, although there was an 0.0.0.0 route pointing to 192.168.3.254, but it doesn't make a difference. In the 501 PIX I can see the request going out, but after that, all is quiet...
Dick
(in reply to MSchaefer)
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:27:34 AM
MSchaefer
Redlob,
can you do a >route print from the 192.168.3.2 computer?  I am not a cisco expert, but it looks like you are missing a route in the PIX 506E.
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:35:11 AM
redlob
Mark,
I've updated the picture with the route table. The thing the bothers me is that I don't see the traffic coming in on the 506.
Dick
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:46:29 AM
MSchaefer
Dick,
I like to take these one connection at a time to see where it drops.
Will your 192.168.3.2 computer accept  a route of:
>10.250.1.0 MASK 255.255.255.0 192.168.3.254
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 9:53:59 AM
MSchaefer
Dick,
Can you add the 192.168.3.0  255.255.255.0 10.250.1.1  route to the 506
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 10:13:22 AM
redlob
Mark,
The 192.168.3.0 on the 506 is not needed, because for the 506, that network is on the outside. All traffic destined for the outside interface is routed to the external interface of the 506. The 192.168.1.0 and 192.168.2.0 can ping to 192.168.3.0, so that route is working.
When traffic comes into the 506, it will forward all to the 1700 router.
I've added the 10.250.1.0 route on my 192.168.3.2 server, but still no go.
Dick
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 10:25:30 AM
MSchaefer
Dick,
You can ping 10.250.1.254 and 10.250.1.1 from 192.168.3.2?
What routes do you have in the ISA server 192.168.1.21?
Have you tried it with the 192.168.3.0 route in the 506?  You can alwys take it out again.
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 10:37:16 AM
MSchaefer
Dick,
Have you added the 192.168.4.0 route to your ISA Server?  Have you added 192.168.4.0 to your Internal Network in ISA?  I assume you added the subnet after you built your ISA Server?
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 10:40:42 AM
MSchaefer
Dick,
Maybe I missed something here.  Can you ping 192.168.4.x from 192.168.1.19 and 192.168.2.19?
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 10:56:54 AM
redlob
Yes, ping from 192.168.1.19 and 192.168.2.19 to 192.168.4.x works.
The 192.168.4.x network is added as the perimeter network in the ISA and allowing all traffic.
I've updated my picture, because I forgot to add the subnet between the PIX and my ISP's router. On both sides there is a 10.250.1.x network, but since all traffic is passed through the vpn tunnel, I don't think this is a problem. (all traffic from 192.168.1.x, 192.168.2.x and 192.168.3.x is working, and has been for over a year now)
The route table on the ISA is:
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
         0.0.0.0          0.0.0.0   82.161.234.137   82.161.234.138     20
      10.49.43.0    255.255.255.0      192.168.1.9     192.168.1.21      1
      10.250.1.0    255.255.255.0      192.168.1.9     192.168.1.21      1
  82.161.234.136  255.255.255.248   82.161.234.138   82.161.234.138     20
  82.161.234.138  255.255.255.255        127.0.0.1        127.0.0.1     20
  82.255.255.255  255.255.255.255   82.161.234.138   82.161.234.138     20
       127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
     192.168.1.0    255.255.255.0     192.168.1.21     192.168.1.21     10
    192.168.1.21  255.255.255.255        127.0.0.1        127.0.0.1     10
   192.168.1.255  255.255.255.255     192.168.1.21     192.168.1.21     10
     192.168.2.0    255.255.255.0      192.168.1.9     192.168.1.21      1
     192.168.3.0    255.255.255.0      192.168.1.9     192.168.1.21      1
     192.168.4.0    255.255.255.0      192.168.4.1      192.168.4.1     10
     192.168.4.1  255.255.255.255        127.0.0.1        127.0.0.1     10
   192.168.4.255  255.255.255.255      192.168.4.1      192.168.4.1     10
       224.0.0.0        240.0.0.0   82.161.234.138   82.161.234.138     20
       224.0.0.0        240.0.0.0     192.168.1.21     192.168.1.21     10
       224.0.0.0        240.0.0.0      192.168.4.1      192.168.4.1     10
255.255.255.255  255.255.255.255   82.161.234.138   82.161.234.138      1
255.255.255.255  255.255.255.255     192.168.1.21     192.168.1.21      1
255.255.255.255  255.255.255.255      192.168.4.1      192.168.4.1      1
Default Gateway:    82.161.234.137
Persistent Routes:
Network Address          Netmask  Gateway Address  Metric
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 11:26:16 AM
MSchaefer
Dick,
You have three NIC cards in your ISA Server?  The diagram only looks like two but your route table looks like three.
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 11:35:19 AM
MSchaefer
Dick,
Your ping does not get to the 506E because you have a NIC card from your ISA server plugged into 82.161.x.x.  Unplug or diable that NIC card and see what you get.  The ping is trying to go directly to your ISA Server on the external NIC card.  By default ping is disabled to or from External IP addresses in ISA.
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 11:55:20 AM
redlob
Mark,
Yes, there is a 3rd card in my ISA, connected to my ISP. This is a 2nd internet line which we will be using soon. I didn't include it on purpose, because it is basically doing nothing at the moment.
Anyhow, I disabled it, and I still cannot ping. Logging on the ISA servers shows nothing. Even debugging the 506 shows no ping requests coming in from the 501 side.
How do you see that the ping is going directly to the external nic ?
Dick
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 11:55:28 AM
MSchaefer
Dick,
Your ISA Server can get to the internet through your internal NIC routed through the 506E right?  Why would you need a third NIC card plugged into the 82.161 router?
Mark
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 12:04:05 PM
redlob
Because that line will be our main internet line in a few weeks. The ISA server will then be our firewall/proxy/vpn server, and the 506 will be connected to same router from our ISP to maintain all our tunnels to branch offices (those have all cisco PIX'es). The ISA will provide VPN for remote /laptop users.
The 192.168.4.0 will be our DMZ in which an exchange 2003 server is installed. Before actually installing exchange 2003 I did the required tests, such as netdiag to find any network problems. That's when I found out that the 192.168.3.0 network is not accessible from the DMZ.
Dick
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 12:05:09 PM
MSchaefer
Dick,
You can't have double loop from your ISA Server to 82.161.x.x router.  You can only have one connection to it.  Either through your internal NIC card routed through the 506E or through the External NIC card.
Do you know how to turn on a live logging query on the ISA Server monitoring tab?
Mark
Post #: 19
RE: ISA2004 in existing PIX environment: connectivity i... - 30.Jun.2006 12:12:13 PM
redlob
Mark,
Yes I have live logging on. I'm using the standard query though, is that sufficient ?
Dick
Post #: 20
