ISA2006 NLB problem
ISA2006 NLB problem - 7.Apr.2008 10:57:44 AM
olkrehan
Hi all, I've seen a lot of postings regarding problems with ISA 2006 EE in NLB mode. Here is a new one...We setup an ISA 2006 array with several protected networks. We use unicast NLB with layer2 switches and a crossover cable for the intraarray communication.So far everything works as expected, traffic flows through both members and is allowed or denied as it should.Our problem is that the cluster, or to be more exactly, both array members don't "see" some of our network hosts. If I try to ping them, the request times out, no log entry in the firewall log - nothing. If I check the ARP table of both members, the host isn't there. Even if I manually add the ARP entry there is no chance to reach the system, neither from the isa itself nor from any other client on any other subnet.Only systems on the same subnet can reach them. Because of this I don't think it's a general network problem but an ISA problem. It seems that the members just won't learn all MAC addresses on the switches they are connected to.The curious thing is that this happens only to our iLO-boards (we use HP ProLiant servers). Normal servers are accessible without any problems. Does anyone here have a clue what this behaviour could cause or even how to make things work again? Best regards,Oliver
RE: ISA2006 NLB problem - 8.Apr.2008 3:05:24 AM
olkrehan
We use Enterasys B3 GBit switches which operate only at layer 2 level.All interfaces of both isa servers are configured with the MaskSourceMAC set to 1 as desribed in the KB article.Using a hub in front of the isa servers is not really an option because we need the gbit performance and I don't know of any hub supporting gbit traffic. Our switch reports the virtual MAC address associated to the nlb team correctly: Virtual MAC on ISA1: ip xxx.xxx.xxx.2 02-BF-C0-A8-3F-01Virtual MAC on ISA2: ip xxx.xxx.xxx.3 02-BF-C0-A8-3F-01 ARP entries on switch: xxx.xxx.xxx.1 02-BF-C0-A8-3F-01xxx.xxx.xxx.2 02-BF-C0-A8-3F-01 It seems that the switch associates two ips with the same virtual MAC but I can't delete the one which is associated to the xxx.xxx.xxx.2Nevertheless, this shouldn't be a problem since most of our hosts act as they should, only few have connection problems.
