ISA2K4 Reset to default values?
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> ISA2K4 Reset to default values? Page: [1]
ISA2K4 Reset to default values? - 15.Nov.2005 1:07:17 AM
XMalibu69X
I have an SBS2003 server with ISA2K4...  is it possible to rollback ISA back to default SBS policies?  I think that i fudged a lot of the settings just playing around with it, but now i want to reset all back to default.  Your help is very much appreciated!  Thanks!
Keith
RE: ISA2K4 Reset to default values? - 15.Nov.2005 8:11:14 AM
sam_hunter
Rerun the connect to Internet Wizard.
(in reply to XMalibu69X)
RE: ISA2K4 Reset to default values? - 16.Nov.2005 3:02:07 AM
HandyAndy
Your best best if you truly hosed it, would be to uninstall ISA, run the CEICW to let SBS know it is only using RRAS and to create the default rule set and then install ISA 2004 clean. At the end of the install it will run the CEICW again for you, make sure to check enable firewall and not do not change my settings.
If you have custom screwed up settings just running the CEICW may not clear them up, the process above should let you start over clean.
HandyAndy a.k.a. Andy Goodman
SBS-MVP, MCP, MSA Small Buiness Specialist
for SBS reated tips see www.SBS-Rocks.com
(in reply to sam_hunter)
RE: ISA2K4 Reset to default values? - 16.Nov.2005 5:32:15 AM
XMalibu69X
Hey guys, thank you very much!
Keith
