ISA 2004, two NICs, PPPoE connection
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> ISA 2004, two NICs, PPPoE connection Page: [1]
ISA 2004, two NICs, PPPoE connection - 23.May2007 10:34:07 AM
fezacakir
Hi there
I got ISA Server 2004 (SP3) with two NICs. At the beginning, I could not connected VPN users to internal network. Then, I changed DSL modem mode from Routing to Bridge. VPN user's connections ok. I didn't set an IP to external nic. External nic requires an IP from DHCP server.
sould I set an IP number to external? If yes, how I can set them?
Thanks.
Feza.
RE: ISA 2004, two NICs, PPPoE connection - 31.May2007 11:45:03 AM
For PPPoE connections, I've had the most luck with putting a NAT device in front of the ISA Firewall and have the NAT device do the PPPoE connection.
(in reply to fezacakir)
RE: ISA 2004, two NICs, PPPoE connection - 17.Oct.2007 12:25:31 PM
ErnieG
So with this setup you do not have to put an IP addrress on the external nic, if you have your nat doing the pppoe?
Ernie Garcia
RE: ISA 2004, two NICs, PPPoE connection - 18.Oct.2007 9:52:32 AM
The NAT device does the PPPoE connection.
(in reply to ErnieG)
