ISA 2006 Install Problem
All Forums >> [ISA Server 2004 General ] >> General >> ISA 2006 Install Problem Page: [1]
ISA 2006 Install Problem - 11.Oct.2006 6:35:00 PM
Peter_Dibbens
Hi Guys I am trying to install ISA 2006
The below error occurs when I attempt to add a second ISA server to the enterprise and attempt to create a replica of the configuration storage container (ADAM)
Setup Failed to connect to the specified Configuration Storage server computer This may be becuuse the local computer needs to be added to the Replicate Configuration Storage server computer set
First I am not able to add the server to the "Replicate Configuration Storage Server" computer set as it is greyed out (I assume this gets populated dynamically)
Read the getting started guide and it never mentions adding additional replicas.
I am no ISA expert and have had this dumped on me (Typical) no one else able to answer the question.
The log states that the server is not able to connect to the Instance of ADAM
BTW this is a completey default install with a single nic no AD policies nothing. I tried adding the server (ISA02) to the system policy rule set but still no go. Name Res etc etc is all working ok.
Thanks again for any help I will continue to investigate, I guess this must be real simple but I cannot spot it.
I have one network defined in my lab environment
Any help would be great thanks Peter
RE: ISA 2006 Install Problem - 14.Oct.2006 10:06:57 AM
Hi Peter,
What's the deal with single NIC? Don't you know that's hork mode and doesn't provide the firewall security you need to make up for the weaknesses in your current firewall deployment?
(in reply to Peter_Dibbens)
RE: ISA 2006 Install Problem - 18.Oct.2006 5:07:54 AM
Peter_Dibbens
The only requirment for this is to use ISA as a proxy not a firewall
Do you have any idea what the problem is??
RE: ISA 2006 Install Problem - 18.Oct.2006 6:52:04 AM
Hi Peter,
But I don't get it. The ISA Firewall is a firewall. Why else would it be called the ISA Firewall? I figured since I've written five books and over 600 articles about the ISA Firewall that I'd know what it was
RE: ISA 2006 Install Problem - 18.Oct.2006 7:41:08 AM
Peter_Dibbens
Hi
So are we saying that this product is not suitable to use as a proxy Server with a single nic?
I do not need to use the Fire wall functionality.
I have to implement a design written by MS for 1400 ISA Servers across 1400 different sites with replication of Adam etc etc. I am not saying that these guys know it all.
However back to my problem i cannot install a replica of the CSS
Thanks again Peter
RE: ISA 2006 Install Problem - 18.Oct.2006 7:13:00 PM
marcus2v
I know its for ISA 2004 but the same pretty much applies ... have you worked through this:
http://www.microsoft.com/technet/isa/2004/plan/ts_css.mspx
RE: ISA 2006 Install Problem - 19.Oct.2006 9:53:59 AM
ORIGINAL: Peter_Dibbens
Hi
Thanks again Peter
Hi Peter,
If MCS wrote you a design, how come they aren't supporting it?
RE: ISA 2006 Install Problem - 19.Oct.2006 12:45:03 PM
u better read this : http://forums.isaserver.org/m_2002029680/mpage_1/key_/tm.htm#2002029680
Windows Expert - IT Pro MVP
RE: ISA 2006 Install Problem - 31.Oct.2006 4:18:56 AM
garry_williams
Hi Peter,
A single NIC ISA configuration is perfectly valid, so long as it is appropriate for your installation scenario. I am currently configuring a single NIC NLB cluster to provide fault tolerant access specifcially to OWA, OMA and Exchange ActiveSync for a client. If the requirement changes in the future we can add NIC(s) and apply a different network template as needed.
In any case, to answer your original question I suspect you were trying to access the Replicate Configuration Storage computer set through the System Policy at the Array level. If you just click on the Firewall Policy node and then access the Toolbox tab in the task pane on the right hand side you can then open Computer Sets and then the Replicate Configuration Storage computer set. Add new machine definition(s) for all machines that are to receive a replica of the CSS data and then commit the change.
Let me know how you get on. I wonder if you'll see the same problem I am experiencing in the next step - right near the end of the installation of the CSS replica the installation fails with the message "setup failed to install ADAM in replica mode (0x80074e46)". I'm using ISA 2006 EE RC1, but I haven't Googled on it yet so it maybe an easy one to fix. Expect a post later in the day Tom ;-)
Good luck,
Garry
(in reply to elmajdal)
RE: ISA 2006 Install Problem - 30.Nov.2006 4:50:48 AM
h4rd1p
Hi Garry,
I am experiencing the same problem with the exact error message (0x80074e46) at the same stage as yourself
Have you had any luck in resolving this issue?
Many Thanks
Hardip
(in reply to garry_williams)
RE: ISA 2006 Install Problem - 13.Dec.2006 8:48:48 AM
hfernandes2001
Hi.
I had this issue!
To resolve this issue, add the computer into the "
Replicate Configuration Storage server computer set" in the ENTERPRISE, not in the array.
This worked for me ....
RE: ISA 2006 Install Problem - 8.Jun.2007 8:41:11 AM
sanchezh
Hi All,
I have the same issue but the Replicate Configuration Storage computer set is greyed for me therefor I cannot add any computer into it
Any Idea?
< Message edited by sanchezh -- 8.Jun.2007 9:33:55 AM >
(in reply to hfernandes2001)
RE: ISA 2006 Install Problem - 21.Jun.2007 3:49:06 PM
Are you conifguring it in the Enterprise policy and not the array policy?
(in reply to sanchezh)
RE: ISA 2006 Install Problem - 13.Aug.2009 7:17:45 AM
merowinger
i had the same problem, but it occured when i tried to install the first isa server in the array. i could solve it as follows:
http://pleasepressanykey.blogspot.com/2009/08/failed-to-run-adam-setup-0x80074e46.html
< Message edited by merowinger -- 13.Aug.2009 7:20:31 AM >
