ISA 2006 does not prompt anonymous users for authentication
ISA 2006 does not prompt anonymous users for authentica... - 11.Jun.2008 10:44:02 AM
ahassim
I have recently set up an ISA 2006 server. I am having a problem with authentication whereby all anonymous users are being denied access. I want these users to be prompted for logon credentials - how do I go about doing this? All AD authenticated users work 100%. Regards, Aadil
RE: ISA 2006 does not prompt anonymous users for authen... - 11.Jun.2008 5:00:00 PM
paulo.oliveira
Hello Aadil, I do not recommend you to mark the check box "Require all users to authenticate", because as you seeing all anonymous access will be denied. Some applications, such as anti-virus programs, doesn´t support authentication. You can create a rule and allow only an AD user set or all authenticated users, for internet access, for example and ISA will allow only this users to access internet. quote:
I want these users to be prompted for logon credentials - how do I go about doing this? Most of browsers pass the credentials of the logged on user, if the computer is joined to domain. Regards, Paulo Oliveira.
RE: ISA 2006 does not prompt anonymous users for authen... - 12.Jun.2008 2:07:51 AM
ahassim
Hi Paul, Thank you for your response. I seem to have found where my problem was - it seems that IE 7 uses intergrated authentication which does not allow for this prompt to pop-up. After disabling this function (Enable Integrated Windows Authentication) in IE (Tools -> Internet Options -> Advanced) - the pop-up is now enabled. Regards, Aadil
RE: ISA 2006 does not prompt anonymous users for authen... - 12.Jun.2008 2:41:58 AM
mmmm Nice Tip !! Thanks for the hint .
RE: ISA 2006 does not prompt anonymous users for authen... - 13.Jun.2008 10:07:39 AM
ahassim
Hi Paulo, Sorry, hope I did not offend you by calling you Paul. I was quite amazed to find that it was Internet Explorer - I didn't even think of it in the beginning. Good thing I have a Microsoft AD/Desktop specialist around who pointed out that it may be the browser that could be causing it. Regards, Aadil
