ISA 2006 webproxy logging to SQL error
All Forums >> [ISA 2006 Web Proxy] >> General >> ISA 2006 webproxy logging to SQL error Page: [1]
ISA 2006 webproxy logging to SQL error - 8.Jan.2008 10:37:19 AM
WillWeber
I've run into an error that I can't find any information about. I'm hoping that someone here can help shed some light on the problem.
I've got logging for the webproxy setup to point to a SQL database on another server in the same domain. When I first set things up I came with an error like this one:
EXECUTE permission denied on object 'sp_batch_insert',
I was able to resolve that one by giving the database owner privledges to the user that is making the connection to the Proxy Log Database.
However, after a day ISA stopped being able to log to the database and the Microsoft Firewall Service shut down (causing ISA to stop working) and I now see the following error message in the event logs:
The ISA Server Web filter failed to log information to SQL Database ISA_Proxy_Log. The SQL Error description is:
Procedure or function sp_batch_insert has too many arguments specified.
I'm completely stumped as to where to go from here. I have no controll over how many arguments are being sent by ISA. I'm not even that familiar with the sp_batch_insert procedure. I'm assuming it's a stored procedure that was setup when I created the Log Database.
Any help or suggestions are greatly appreciated. Thank you,
Will
