ISA Blocking OWA HELP!!
All Forums >> [ISA Server 2004 General ] >> Exchange Publishing >> ISA Blocking OWA HELP!! Page: [1]
ISA Blocking OWA HELP!! - 20.Mar.2012 5:33:32 PM
Ap3xne
Here is my problem. When I had to renew my SSL Cert my OWA no longer works. I have done everything every webpage has said with no luck.
Here is what the webpage says when I go to it with /exchange
Error Code 11001: Host not found
Background: This error indicates that the gateway or proxy server could not find the IP address of an upstream (Web) server. This is usually due to a DNS-related error.
This is what it says when I do mail.mydomain.com
We have always used mail.mydomain.com/exchange to access OWA but does not work. Internal works fine. It is going to the default rule in ISA when I am trying to access it this causing it to give me the messages above.
PLEASE HELP. I will respond quickly.
RE: ISA Blocking OWA HELP!! - 20.Mar.2012 8:21:54 PM
Juke
Try this. http://www.expta.com/2009/01/how-to-install-new-certificate-on-isa.html.
(in reply to Ap3xne)
RE: ISA Blocking OWA HELP!! - 20.Mar.2012 9:22:54 PM
Ap3xne
I have already done that and still the same message. I did do one thing different. I first removed the cert under directory security and then ran the wizard and selected install new cert. I still have the old cert in my personal folder. Should it not matter if the old one is still in there or not?
