jun1or
ORIGINAL: pwindell 1. Forget Ping. Ping is worthless. The fact that something can't be pinged is meaningless. If you want to test some type of commincation, then use the same protocol used in the communication. Want to test http, then use http,...want to test DNS, then use DNS,..want to test Telnet, then use Telnet. 2. Connectivity verifiers are worthless if you create them improperly,...such as using Ping to test something that is not Ping. Forget the Verifiers. 3. Now, let's start from the beginning A. Uninstall ISA from the Box. Make sure the box uses only the AD/DNS and none other (same way with every other machine on the LAN). B. Join the box to the Domian. If it is already joined,..then unjoin it and move to a Workgroup,...reboot,...then rejoin it to the Domain. Now we know the Join is a "good" one,...which also proves that the machine is handling DNS correctly. Add or verify the Static Routes to the OS's routing table as we mentioned in previous posts. C. Install ISA and choose the Single-Nic Cache Server Template D. Make sure your Firewall,...whatever that may be,...allows the AD/DNS Server to make outbound DNS Queries. The AD/DNS will not use the ISA for this,...DNS does not fall within the "role" of a CERN Compliant Web Proxy (like a single-nic ISA) which only does http, https, read-only ftp, and gopher. Make sure that this same Firewall does not allow outbound http/https/ftp from the Users or they will be able to bypass the ISA by removing the proxy settings from their browser. E. Create Access Rules for Users Source: Internal Destin: Internal (yes, internal) Protocol: http, https, ftp Users: <whatever> F. ISA itself will not be able to browse the Net. It is by default and is on purpose,...intensional G. ISA's System Policies will allow only the minimum communication with the LAN (the DC) for it to do its job. It will not be able to run around on the Internet or the LAN in the same way as other machines,...it is not supposed to. If it does not work,...particularly concerning the routing and the Static Routes, then you have not correctly described your LAN Topology Design to us. Here's some additional information (it says ISA2004, but it is still that same)... The features and limitations of a single-homed ISA Server 2004 computer http://support.microsoft.com/kb/838364/en-us http://www.microsoft.com/technet/prodtechnol/isa/2004/plan/single_adapter.mspx Configuring ISA Server 2004 on a Single Adapter Computer (http://www.microsoft.com/technet/prodtechnol/isa/2004/plan/single_adapter.mspx) I really appreciate your help on this, Two other question before I carry out these steps. 1) Do I have to add all the subnets to the routing table before installing (i.e. 192.168.0.0, 192.168.1.0, 10.10.1.0, 10.10.2.0 etc)? 2) What should the default gateway point to? I know you mentioned they should not point to the ISA, should these point to the ISA’s configured gateway (i.e. ISA’s IP 192.168.0.22 Gateway: 192.168.0.254)? Again Many thanks for your help
