ISA not routing traffic to webserver in DMZ Help pls!
All Forums >> [ISA 2006 Firewall] >> DMZ >> ISA not routing traffic to webserver in DMZ Help pls! Page: [1]
ISA not routing traffic to webserver in DMZ Help pls! - 10.Nov.2010 2:52:45 PM
CJJ
Running TMG 2010 SP1 with Update 1, I have created a NAT DMZ with the following configuration
Internal Nic:
IP 192.8.xxx.xxx
Subnet 255.255.254.0
DNS Set but no gateway
External Nic:
IP 173.xxx.xxx.217 and 173.xxx.xxx.215<-- Webserver external ip
Subnet 255.255.255.248
Gateway set with no DNS
DMZ Nic:
IP 192.168.xxx.1
No dns and no gateway set
What’s happening is when a request comes in from the internet it goes to localhost instead of the listener I created grabbing the request for http and forwarding it to my webserver in the DMZ at ip 192.168.xxx.2 , any idea what I would be overlooking or doing wrong ?
RE: ISA not routing traffic to webserver in DMZ Help pls! - 8.Feb.2011 1:33:32 PM
pwindell
Internal:
1. Address Range is not a valid RFC Private Range
2. Subnet is overloaded. Should not go below /24,...meaning don't have subnets larger than 254 Hosts
3. For every 200 Hosts create a new /24bit segment and put a LAN Router between them.  The ISA can act as a LAN Router if you put yet another Nic into it, but ISA is not a full-featured LAN Router and cannot be expected to perform like one.
External:
Looks fine
DMZ:
Looks ok but the mask is a waste of time.  Just use a /24bit segment and forget it.  Just make sure it is not the same as any range that might potentially ever be used on the Internal side.
Fix these other things. Then we can look at the listener and publishing rule.
Phillip Windell
(in reply to CJJ)
