Importing Access Rules not work
All Forums >> [ISA 2006 Firewall] >> Access Policies >> Importing Access Rules not work Page: [1]
Importing Access Rules not work - 2.Jun.2008 11:13:29 AM
paulo.oliveira
Iīm having a problem to modify a deny access rule. Hereīs the problem:
I want to remove some sites from my deny access rule, I have exported the rule and edited using wordpad.
I removed the websites that I want to and imported the .xml back to my deny rule, but it didnīt worked, the website is still blocked!
When I export the rule to see whatīs wrong, the website that I just removed is still in there!
Can anyone tell me whatīs going on?
I have an ISA 2006 SE with supp. pack running on a windows 2003 sp2.
Regards.
RE: Importing Access Rules not work - 17.Jun.2008 7:58:04 AM
Status: online
Hi Paulo,
Make the changes in the ISA Firewall console instead of editing the text file. That's why they make a GUI that's had thousands of hours of testing.
(in reply to paulo.oliveira)
RE: Importing Access Rules not work - 17.Jun.2008 10:18:03 AM
paulo.oliveira
thanks for this info. But, in my case I have a hundreds of sites in my black list, splited in different categories. So, if I just use ISA management console it will take too long to find out what I want.
Paulo Oliveira.
RE: Importing Access Rules not work - 18.Jun.2008 12:01:54 PM
Status: online
Hi Paulo,
Ah, I see.
Did you remove the old list and import the new one?
RE: Importing Access Rules not work - 18.Jun.2008 2:20:14 PM
paulo.oliveira
no, I did not. I just exported the actual list to a .xml file, modified the exported .xml file and imported again to ISA.
For example, I removed 01 website from the .xml. But, when a import this .xml file back to ISA, it stills there!
Paulo Oliveira.
RE: Importing Access Rules not work - 22.Jun.2008 11:15:32 AM
Status: online
Maybe it didn't overwrite the existing information?
RE: Importing Access Rules not work - 23.Jun.2008 9:27:20 AM
paulo.oliveira
I thought it so too. I just needed confirmation. But I think this is the "problem". In fact theres nothing saying "overwrite".
Thanks for your help!
RE: Importing Access Rules not work - 24.Jun.2008 9:24:49 AM
Status: online
Unlike when you import the whole machine policy.
I'll have to check up on this!
