Importing Destination sets
Importing Destination sets - 2.Sep.2004 11:56:00 AM
TomCat1
Supposing someone had a download set file called "Banned Advertisement Sites.xml"; exactly how would one import this file into an HTTP ISA 2004 denial rule? Thanks!
RE: Importing Destination sets - 2.Sep.2004 2:01:00 PM
I have a script that will allow this. Send me a note. You'll have to find your own sites, though.
HTH, Tom
RE: Importing Destination sets - 5.Sep.2004 8:57:00 AM
azfar
Please send me a copy azfarhusain@yahoo.com Thanks.
RE: Importing Destination sets - 6.Sep.2004 6:12:00 PM
azfar
Thanks Tom.
RE: Importing Destination sets - 2.Oct.2004 9:37:00 AM
munnobhai
When running this vbs an error returns : the system cannot find the file specified.
Line:5 Char:1 Code:80070002 Source:(null)
even the file is there (urls.txt)
RE: Importing Destination sets - 2.Oct.2004 8:13:00 PM
munnobhai
Hi, Tom, is there any prior setting to run this vbs ??
RE: Importing Destination sets - 3.Oct.2004 5:35:00 PM
munnobhai
Dear Tom, I have solved the problem by doing the following:
1.Adding a url set name manually ('urls' here). 2.Adding a line in your code : code:
Set Isa = CreateObject("FPC.Root") Set CurArray = Isa.GetContainingArray Set RuleElements = CurArray.RuleElements Set URLSets = RuleElements.URLSets Set URLSet = URLSets.Item("urls") Set FileSys = CreateObject("Scripting.FileSystemObject") Set UrlsFile = FileSys.OpenTextFile("urls.txt", 1) For i = 1 to URLSet.Count URLSet.Remove 1 Next ON Error Resume Next <<<<<------ this line Do While UrlsFile.AtEndOfStream <> True URLSet.Add UrlsFile.ReadLine Loop WScript.Echo "Saving..." CurArray.Save WScript.Echo "Done"
Thanks for the code, Regards, Hunaid Haroon
RE: Importing Destination sets - 7.Oct.2004 3:43:00 PM
munnobhai
Hi, The wording '<<< this line' is only to mention the addition dont put it in your code !
RE: Importing Destination sets - 7.Oct.2004 5:56:00 PM
TomCat1
Try Surf Control for ISA Server 2004. It worked for me! --Tom C
RE: Importing Destination sets - 7.Oct.2004 7:28:00 PM
Cturtle
quote: Originally posted by tshinder: I have a script that will allow this. Send me a note. You'll have to find your own sites, though.
Tomcat1 spoke about "Banned Advertisement Sites.xml". Why did you advice to use a script when importing this .xmlfile is the most simple option?
Regards.
