Inteent Connection on clinet using default gateway?
Inteent Connection on clinet using default gateway? - 27.Jul.2007 12:08:19 AM
nilesh20jain
hi,i have a ISA Server and two client machine and i m trying to connect internet on thr client throgh server but i want to connect internet on clint without mentioning proxy setting in the web browser ,i want to connect internet using default gateway on client machine so help me in this as soon as possible
< Message edited by nilesh20jain -- 27.Jul.2007 12:12:07 AM >
RE: Inteent Connection on clinet using default gateway? - 27.Jul.2007 2:45:17 AM
Status: online
Hi, On Your Clients Machines: 1- Set the DG to point to ISA Server 2- Set the DNS to point to your Internal DNS Server On Your ISA Server : 1- Create a rule allow> protocols> From Internal > To External > All Users 2- create a rule for your DNS Server , read here : http://elmajdal.net/isaserver/Internal_DNS_Forwarding.aspx HTH, Tarek
RE: Inteent Connection on clinet using default gateway? - 27.Jul.2007 4:55:39 AM
nilesh20jain
thnaks for the information but i want to tell u that i dont have DNS Server, i just leave it blank and i have a winodws 2003 server with 2 clients so tell me how to connect client to the interent using ISA Server 2006 on winods 2003 environment reply soon
RE: Inteent Connection on clinet using default gateway? - 28.Jul.2007 12:28:33 AM
iaculallad
If you don't have a DNS Server, then you can configure your Internal LAN card (If you have) to point to your ISP's DNS server..
Ian Ace Culallad, CCNA -There's Life in Every Star-
RE: Inteent Connection on clinet using default gateway? - 28.Jul.2007 1:15:37 AM
nilesh20jain
hii, i have two different connection from two different ISP's although we have a program which switches over from main connection to backup whenver necessary i.e the main connection is not available even the connection are ADSL broad band connection so the DNS Server of the ISP keeps on changing whenver i connect isnt it so? please advise
RE: Inteent Connection on clinet using default gateway? - 29.Jul.2007 2:31:00 AM
Status: online
What would it take to configure a proper DNS Server ?? few minutes ? have an Internal DNS Server, and make it responsible for forwarding requests to your ISPs DNS Server. in the Forwarder tab, configure the list of the IPs for both ISP DNS Servers.
RE: Inteent Connection on clinet using default gateway? - 30.Jul.2007 1:13:54 AM
mzakir
Nilesh, Just do it & check, I am sure it will work... it's my experienced
Malek Zakir MCP,MCSA:Security,MCSA:Messaging,MCTS,CCNA,DCH
RE: Inteent Connection on clinet using default gateway? - 31.Jul.2007 6:58:13 AM
nilesh20jain
hi ,thanks mr mzakir and mr elmajdal Its Working but i have got few problem that i wanna share with u 1) When i make a firewall policy on isa server 2006 and applied the changes the changes are not reflected immidiately.even the loginng which is related to the specifed policy is not shown 2)i have found that the internet speed gets decreased when i use ISA server 3)When i opens the website www.vistaicons.com on a specific client but image on the website doesnot load and i have found a error in isa server logging is 0x80074e24 FWX_E_CONNECTION_KILLED whenever i opened the website ,i have tried this in both browser intenet explorer and mozilla so plz advise me Thanks & Regards Nilesh
< Message edited by nilesh20jain -- 1.Aug.2007 1:36:35 AM >
RE: Inteent Connection on clinet using default gateway? - 31.Jul.2007 7:03:08 AM
nilesh20jain
reply soon
< Message edited by nilesh20jain -- 31.Jul.2007 7:04:50 AM >
RE: Internet Connection on client using default gateway... - 31.Jul.2007 12:29:17 PM
nkruger
ORIGINAL: elmajdal 1- Set the DG to point to ISA Server 2- Set the DNS to point to your Internal DNS Server Hi Guys, This is all good and well when the client resides on the same subnet as the FW, to enable it to point to the FW as DG... .... but when the client resides on another subnet and has to use a remote router's eth interface as a DG to get to the subnet where the FW resides? My situation is as follows: FW in subnet 1 serves as internet gateway for all, with a WAN link (internal to FW view) to a remote site subnet 2 from where i need to get clients (customers) to access the internet, via the FW in subnet 1, without having to enter proxy information into their browser or load any software, being customers' machines and all. The solution works 100% with pointing client to FW as DG when on local subnet where the FW resides, but when on remote subnet... it does not work.... Subnet 1 Router points to the FW as DG for connections comming from remote subnet via WAN. I was thinking of installing a FW in the remote site subnet 2 and setup as DG for local clients requiring this config and have that forward to the FW in subnet 1, but would like to run this as seamless as possible without spending time and resources on another fw in subnet 2 any ideas? thanks in advance Niel Kruger
