Isa 2004 denied http connection
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Isa 2004 denied http connection Page: [1]
Isa 2004 denied http connection - 22.Oct.2004 2:23:00 PM
speedhost
hi.
I have a very simple test edge firewall setup which i'm having some problems with or at least I think itĘs a problem..
195.215.5.64 is external ip
192.168.150.1 is internal ip
192.168.150.5 is the web server.
I published the web server via the web server publishing guide
The problem I have is if you monitor the http connections you will see that the isa are
Denying some connection..
Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL
80.164.159.162 HP-M3TQ01JEV81B - TCP - - 54728 0 0 0 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED 0x0 0x0 Firewall 22-10-2004 14:13:25 195.215.5.64 80 HTTP Denied Connection 80.164.159.162 External Local Host - -
"the web server are using the isa as gateway and i set >requests appear to come from original client client<"
Any ideas ??
RE: Isa 2004 denied http connection - 22.Oct.2004 2:56:00 PM
These are likely people just trying to fingerprint you:
http://www.tech-archive.net/Archive/ISA/microsoft.public.isaserver/2004-08/0464.html
ISA is doing it's job! [Smile]
The 80.X range is normally NTL broadband - hence script kiddie domain [Wink]
[ October 22, 2004, 02:57 PM: Message edited by: Jason Jones ]
(in reply to speedhost)
RE: Isa 2004 denied http connection - 22.Oct.2004 4:43:00 PM
speedhost
hi jj
thanks for the reply..
i don't think this is an attack..
if you go though the logs you will see the following pattern:
83.73.0.107 - 16:21:55 - Initiated Connection
0.0.0.0 - 16:21:55 - Allowed Connection - http://192.168.150.5/dummy.asp?website_id=56571&secID=545156
0.0.0.0 - 16:21:59 - Allowed Connection - http://192.168.150.5/dummy.asp?website_id=59685&secID=987561
83.73.0.107 - 16:23:01 - HTTP closed Connection
83.73.0.107 - 16:23:11 - 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED
is the isa server ending the connections prematuraly
cheers Brian
RE: Isa 2004 denied http connection - 22.Oct.2004 8:22:00 PM
Ah right, you didn't say the error was from the same source as the previous allowed connection. In that case then I am not sure, but could be a bug I guess...
Is the website working properly?? If so, either dont worry about it or place a call with MS.
I had a similar thing with errors during RPC over HTTP traffic and spoke to MS - they said "oh yes, we know it does that, but you can just ignore them as they are cosmetic errors due to how ISA is handling the requests"
Maybe it is the same???
[ October 22, 2004, 08:26 PM: Message edited by: Jason Jones ]
RE: Isa 2004 denied http connection - 5.Feb.2005 5:00:00 PM
speedhost
Hi all..
has anyone else experienced the same problem and found a solution..?
we dropped the isa because of this but I would like to get back on an application layer firewall
Brian
RE: Isa 2004 denied http connection - 5.Feb.2005 10:27:00 PM
penrose.l@2college.nl
"tcp not syn" very well known problem that was solved here about 20 times before you should try to search on the forums.
Lex P
RE: Isa 2004 denied http connection - 6.Feb.2005 11:06:00 AM
speedhost
Hi lex..
thanks for posting but i don't really agree..
I have searched the message board and i do see that you make two statements.
1. you should add the regfix in windows 2003
2. You are saying that it's because that i use NAT where it should have been route..
Your own problem where a file copying between a client and a server. and yes there are a problem here. But as the kb states : This fix applies only to the SMB protocol traffic over TCP NetBIOS port 139 .
As you can see from the above i'm having the problem on a web server.
if you take your second statement: You should use route instead of NAT.
In this Egde firewall in have 2 nic's
Wan having 1 public ip address
Lan having multiple (private) ip adresses
If i'm connecting muliple lan clients though a single ip/interface I am only left with the NAT solution..
or am I messing something here ??
Brian
Ps: I have looked though the 29 threads about tcp not syn but i don't really see people saying it was solved with the above?
pps: My own personal oppinion is that it might be a bug in the HTTP filters.
with Verify normalization & block high bit characters enabled i get 2-3 times more "tcp not syn".
Why would it do that when still calling the same asp page [Confused] (not being an http filter guru at all)
RE: Isa 2004 denied http connection - 19.Nov.2005 2:45:46 PM
cmeilicke
I'm having the same problem with two networks connected trough an ISA server with two NICs. Both NICs are part of the internal network, the rule is setted to allow all traffic, but i guess the server is still filtering something.
RE: Isa 2004 denied http connection - 19.Nov.2005 3:05:32 PM
Hi cmeilicke,
I don't think it is the *same* problem. The 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED is given if ISA receives a packet that don't belong to an existent connection, at least from the point of view of the ISA server.
In the case of Brian, the ISA log shows
As you can see, the HTTP connection was already closed from the point of view of ISA. So, this is a cosmitic problem due to the way ISA and the browser closes the connection. Nothing to be worried about in this case.
However, in your case you said
Now, that's an illegal and not-supported configuration. Each ISA interface should be on his own Network ID. So, you'll have to redesign your ISA network setup to solve that problem.
(in reply to cmeilicke)
RE: Isa 2004 denied http connection - 4.Jan.2008 12:35:38 PM
IanP
I'm having the same issue on both HTTP and HTTPS and not just from a single Client IP Address.  The pattern is similar, if not the same as mentioned above.  We get a successful connection 0x0 as the status, followed by 0x80074e21 (FWX_E_ABORTIVE_SHUTDOWN) then the 0xc0040017 (FWX_E_TCP_NOT_SYN_PACKET_DROPPED)...  I might have the errors round the wrong as I've staring at this all day.  This seems to happen in 1 out of 100 connections and even during an active session when the page is changed in the client's browser.  The logs seem to imply that our web listener isn't responding to the connection and ISA is just terminating it.  We're using ISA 2006 Standard with two network cards (one internal and one external) and NAT.
Can anyone shed any light on this please?
(in reply to spouseele)
