Java/ActiveX - Not Working?
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Java/ActiveX - Not Working? Page: [1]
Java/ActiveX - Not Working? - 17.Oct.2006 12:14:52 PM
inspectorgadjet
I've just started using ISA Server 2006 on my home office network as part of my action pack subscription, and I'm getting to grips with it slowly. I've hit a wall with one section though.
I currently have a broadband connection at home with a D-Link router controlling everything. This router will only allow one firewall rule for port 80. I have set this rule to forward to the ISA server.
I also have four wireless network cameras which each contain their own web server which run both java and activex controls for viewing live video. I'd like to use these cameras to keep tabs on things at home while I'm not there.
I've configured ISA to allow connections to the camera web servers, and that seems to be working. I can connect to the cameras and login to the admin interface. However, when I click on the view video button - for java or activex - the page will load, but the control will just remain blank. On java, it shows the java loading screen for a few seconds, but then goes blank as well. This happens on all four of the cameras.
I think I may have missed out something in my configuration but I can't think what. I've been reading forums and web articles all day, but I still can't find an answer. I've tried dozens of settings, but nothing seems to be helping. Can anyone tell me what I should do to make the activex and java controls work?
Thanks. :)
RE: Java/ActiveX - Not Working? - 19.Oct.2006 6:30:07 AM
stanley
Just check out most of this cameras stream video on different ports rather than port 80
Stanley
(in reply to inspectorgadjet)
RE: Java/ActiveX - Not Working? - 19.Oct.2006 7:45:56 AM
inspectorgadjet
I've been looking through the logs, and can't find any sign of any other ports at all.
The only thing that I can find that might be something is a denied request for a URL: http://192.168.0.103/MJPEG.CGI. That URL is my ISA server's IP. I'm sure that it should probably be requesting that URL from the camera's IP instead of the ISA server.
(in reply to stanley)
RE: Java/ActiveX - Not Working? - 21.Oct.2006 6:17:02 AM
stanley
Can you Paste the log from the monitoring
Stanley
RE: Java/ActiveX - Not Working? - 22.Oct.2006 7:43:41 AM
inspectorgadjet
Here's the log. I've modified server names and IP addresses to fake ones. There's quite a lot of log here. I just thought I would paste everything from the few minutes I monitored.
I have noticed some things to do with java in the logs, but I'm still trying to figure out what they mean.
Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Authentication Server Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:31:54 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:31:54 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:31:59 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:31:59 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:04 29333 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:04 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568bc  - - - 22/10/2006 11:32:05 0 563 1883 414  200  0x40040000 0x400 Web Proxy Filter  22/10/2006 12:32:05 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:05 29333 0 685 2045 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:05 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:05 29334 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:05 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568bd  - - - 22/10/2006 11:32:05 0 297 2131 455  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:05 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/top.htm?Currenttime=2006-10-22%2012:32:27
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:05 29335 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:05 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:05 29334 0 726 2293 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:05 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:05 29336 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:05 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:06 4865 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:06 4866 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER http://camera.web.co.uk/top.htm?Currenttime=2006-10-22 12:32:27 camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568bf  - - - 22/10/2006 11:32:06 0 438 2845 342  200  0x40040000 0x400 Web Proxy Filter  22/10/2006 12:32:06 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/logo.gif
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:06 29335 0 613 3025 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER http://camera.web.co.uk/top.htm?Currenttime=2006-10-22 12:32:27 camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c0  - - - 22/10/2006 11:32:06 0 422 12951 370  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:06 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/IMAGE.JPG?cidx=200610221227315629566
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:06 29336 0 761 13371 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:06 29337 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c1  - - - 22/10/2006 11:32:06 0 125 107 240  404  0x40000000 0x482 Web Proxy Filter  22/10/2006 12:32:06 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/favicon.ico
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:06 29337 0 471 213 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:06 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:08 4866 2000 1014 3400 0x80074e21 FWX_E_ABORTIVE_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:08 192.168.0.103 80 HTTP Closed Connection  82.19.88.214  Internal Local Host - -
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:32:08 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:32:08 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:10 29338 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:10 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; Creative ZENcast v1.00.12) Yes Reverse Proxy ISASERVER http://camera.web.co.uk/top.htm?Currenttime=2006-10-22 12:32:27 camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c2  - - - 22/10/2006 11:32:11 0 406 3976 504  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:11 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/Jview.htm
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:11 29338 0 815 4174 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:11 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:32:13 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:32:13 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:20 29342 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:20 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:20 29343 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:20 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c5  - - - 22/10/2006 11:32:20 0 313 2367 294  10053  0x40040000 0x402 Web Proxy Filter  22/10/2006 12:32:20 192.168.0.108 80 http Failed Connection Attempt camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:20 29342 0 565 6084 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:20 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c7  - - - 22/10/2006 11:32:21 0 641 16030 251  200  0x40040000 0x400 Web Proxy Filter  22/10/2006 12:32:21 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29343 0 722 16490 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29344 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29345 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:21 4870 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:21 4871 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:21 4870 0 502 1684 0x80074e21 FWX_E_ABORTIVE_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.103 80 HTTP Closed Connection  82.19.88.214  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:21 4873 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568c8  - - - 22/10/2006 11:32:21 0 219 2297 297  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:21 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug$SI.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29344 0 568 2459 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568ca  - - - 22/10/2006 11:32:21 0 547 2297 254  200  0x40040000 0x400 Web Proxy Filter  22/10/2006 12:32:21 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug$SI.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29345 0 525 2459 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:21 29346 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:21 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:22 29347 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:22 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568cc  - - - 22/10/2006 11:32:22 0 437 3051 297  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:22 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug$TS.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:22 29346 0 608 3246 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:22 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568cb  - - - 22/10/2006 11:32:22 0 594 3051 254  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:22 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug$TS.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:22 29347 0 525 3206 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:22 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:22 29348 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:22 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:22 29349 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:22 192.168.0.108 80 HTTP Initiated Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568ce  - - - 22/10/2006 11:32:23 0 406 16030 294  200  0x40040000 0x480 Web Proxy Filter  22/10/2006 12:32:23 192.168.0.108 80 http Allowed Connection camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:23 29348 0 725 16450 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:23 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:32:23 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:32:23 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:23 4874 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:23 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
0.0.0.0 Mozilla/4.0 (Windows XP 5.1) Java/1.5.0_07 Yes Reverse Proxy ISASERVER  camera.web.co.uk TCP  Internet - -  - Req ID: 0e6568d0  - - - 22/10/2006 11:32:23 0 609 2367 251  10053  0x40040000 0x402 Web Proxy Filter  22/10/2006 12:32:23 192.168.0.108 80 http Failed Connection Attempt camera1 82.19.88.214 anonymous Internal  GET http://192.168.0.108/xplug.class
192.168.0.103    ISASERVER -  TCP -      -    22/10/2006 11:32:23 29349 0 522 6084 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:23 192.168.0.108 80 HTTP Closed Connection  192.168.0.103  Local Host Internal - -
0.0.0.0 user Yes Reverse Proxy ISASERVER  192.168.0.103 TCP   - -  - Req ID: 0e6568d3  - - - 22/10/2006 11:32:23 0 1 2264 68  12202 The ISA Server denied the specified Uniform Resource Locator (URL).  0x8 0x0 Web Proxy Filter  22/10/2006 12:32:23 192.168.0.103 80 http Denied Connection Default rule 82.19.88.214 anonymous Internal  GET http://192.168.0.103/MJPEG.CGI
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:25 4874 1969 539 2735 0x80074e21 FWX_E_ABORTIVE_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:25 192.168.0.103 80 HTTP Closed Connection  82.19.88.214  Internal Local Host - -
192.168.0.108    ISASERVER -  TCP -      -    22/10/2006 11:32:25 80 0 0 0 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED  0x0 0x0 Firewall - 22/10/2006 12:32:25 192.168.0.103 29349 Unidentified IP Traffic Denied Connection  192.168.0.108  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:25 4875 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:25 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:32:28 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:32:28 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
192.168.0.100    ISASERVER -  TCP -      -    22/10/2006 11:32:36 4973 306000 3299 3166 0x80074e21 FWX_E_ABORTIVE_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:36 192.168.0.103 139 NetBios Session Closed Connection File Sharing 192.168.0.100  Internal Local Host - -
0.0.0.0 user Yes Reverse Proxy ISASERVER  192.168.0.103 TCP   - -  - Req ID: 0e6568d5  - - - 22/10/2006 11:32:36 0 1 2264 68  12202 The ISA Server denied the specified Uniform Resource Locator (URL).  0x8 0x0 Web Proxy Filter  22/10/2006 12:32:36 192.168.0.103 80 http Denied Connection Default rule 82.19.88.214 anonymous Internal  GET http://192.168.0.103/MJPEG.CGI
0.0.0.0    ISASERVER -  UDP -      -    22/10/2006 11:32:38 68 0 0 0 0xc004000d FWX_E_POLICY_RULES_DENIED  0x0 0x0 Firewall - 22/10/2006 12:32:38 255.255.255.255 67 DHCP (request) Denied Connection Default rule 0.0.0.0  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:38 4875 13000 356 2592 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN  0x0 0x0 Firewall - 22/10/2006 12:32:38 192.168.0.103 80 HTTP Closed Connection  82.19.88.214  Internal Local Host - -
82.19.88.214    ISASERVER -  TCP -      -    22/10/2006 11:32:38 4876 0 0 0 0x0 ERROR_SUCCESS  0x0 0x0 Firewall - 22/10/2006 12:32:38 192.168.0.103 80 HTTP Initiated Connection  82.19.88.214  Internal Local Host - -
RE: Java/ActiveX - Not Working? - 31.Oct.2006 11:20:30 AM
inspectorgadjet
No ideas anyone?
RE: Java/ActiveX - Not Working? Possibly CGI being bloc... - 28.Nov.2006 5:11:40 PM
inspectorgadjet
I'm still scratching my head on this one. I think I've convinced myself that it is actually a cgi file that is being blocked or possibly something in the url. It almost looks as if the HTTP redirector is not firing for cgi files. I've tried a different brand of ip camera now which uses different software but still an activex control for viewing. The log message is:
0.0.0.0  Yes Reverse Proxy Server  192.168.0.103 TCP   - -  - Req ID: 0aa85ccf  - - - 28/11/2006 20:59:00 0 1 2264 114  12202 The ISA Server denied the specified Uniform Resource Locator (URL).  0x8 0x0 Web Proxy Filter  28/11/2006 20:59:00 192.168.0.103 80 http Denied Connection Default rule 84.58.89.23 anonymous Internal  GET http://192.168.0.103/cgi-bin/getimage.cgi?motion=1
192.168.0.103 is the IP address of the ISA server, not the actual camera. So it almost looks like the HTTP redirect is redirecting html requests to the camera, but trying to locate cgi requests on the isa server itself.
This problem is really frustrating me at the moment and I've got to figure it out. Someone must know what's happening. Please help me!!! Before I tear my last hair out.
