Logging and Reporting Questions
All Forums >> [ISA Server 2004 Firewall] >> Logging and Reporting >> Logging and Reporting Questions Page: [1]
Logging and Reporting Questions - 12.Jun.2007 9:45:37 AM
CryptoPKI
At work I have an ISA box setup as a web proxy server.  I setup a few users to use this so I can log their web activity, but when I start a query I see their username as "anonymous" how can I get ISA to display their appropriate username in the query?
-CryptoPKI
< Message edited by CryptoPKI -- 12.Jun.2007 10:02:27 AM >
RE: Logging and Reporting Questions - 12.Jun.2007 11:45:01 AM
to log username, your clients should be configure as WebProxy and/or firewall client .
Tarek
(in reply to CryptoPKI)
RE: Logging and Reporting Questions - 12.Jun.2007 11:52:01 AM
CryptoPKI
If you mean setting up their IE browsers to use our proxy server then yes they are setup as a web proxy client..  Also under the internal configuration properties I have "EnableWeb Proxy Clients" checked off, with unlimited connections and integrated authentication.
Am I missing something else?
< Message edited by CryptoPKI -- 12.Jun.2007 11:57:14 AM >
(in reply to elmajdal)
RE: Logging and Reporting Questions - 12.Jun.2007 12:09:03 PM
on the contrary, if you need Web Proxy to be enabled, you need to check this option :
Tarek
RE: Logging and Reporting Questions - 12.Jun.2007 12:18:01 PM
CryptoPKI
Yep, that's what I have enabled.  Users can browse the web fine using the ISA server, it's just when I check the logs the user is always anonymous.  This would be fine but our users are on a citrix environment so I only see the acutal server as the ip address browsing the web.
RE: Logging and Reporting Questions - 12.Jun.2007 2:28:43 PM
What rules do you have for outbound on your ISA Server? make sure not to use the ALL Users codition, and user usernames/group from your AD
Tarek
RE: Logging and Reporting Questions - 12.Jun.2007 2:51:36 PM
CryptoPKI
Yeah, I was using the "All Users" group... Whenever I try making a group then adding users from Active Directory, I get this error:
I am running Win 2k3 SP1 w/ ISA 2k4 standard.. I was told to add SP3 for ISA but whenever I add that service pack the firewall service wont start.
RE: Logging and Reporting Questions - 12.Jun.2007 3:49:58 PM
indeed, you need at least ISA 2004 SP1 to solve the rpc problem.
for the SP3 problem, check this : http://blogs.technet.com/isablog/archive/2007/05/03/isa-server-2004-service-pack-3-rollback-failure-and-temporary-resolution.aspx
Tarek
