MEMORY ALLOCATION FOR MSDE
MEMORY ALLOCATION FOR MSDE - 6.Dec.2005 3:50:28 PM
jogreg
Currently the MSDE process is taking up 1.5 GB of RAM, I checked the allocated memory and is set to the default (2147483647). What is the recommended amount of memory that should be allocated for MSDE? In the next few months there will be about 1000 users going through the ISA server. It's only used as a Proxy Server. Would it make a big difference if a change the web proxy logging to W3c format instead of MSDE?? Thanks in advance
RE: MEMORY ALLOCATION FOR MSDE - 4.Jan.2006 7:47:44 AM
Covani
Hi, the same here.. Use SQL Server 2000 and ISA 2004 Enterprise on same server. Currently 1.5 GB ram resource only for mssql process, although I have disabled SQL server from services. It runs only the mssql$ for ISA.. any suggestions?
RE: MEMORY ALLOCATION FOR MSDE - 4.Jan.2006 3:09:39 PM
LLigetfa
Do you mean any OTHER suggestions? What is wrong with the link Tom posted?
RE: MEMORY ALLOCATION FOR MSDE - 6.Jan.2006 4:10:31 PM
pruittwh
I had the same problem. MSSQL$MSFW was causing memory threshold alerts (monitoring via NetIQ). I changed the logging method to W3C file format in an effort to stop ISA from using MSDE. Admitting my ignorance, is the MSSQL@MSFW service necessary if I'm not logging to an MSDE database? Microsoft Firewall and SQLAgent$MSFW are both shown as dependencies on this service. Can I disable the service? or will it cause the Firewall not to start? I was guessing that since I'm not logging to an MSDE database, I could solve the memory issue without limiting the amount of memory that the service hogs. Thoughts? Comments? Thanks, William
RE: MEMORY ALLOCATION FOR MSDE - 6.Jan.2006 4:39:33 PM
Hi William, You can remove the SQL logging service by rerunning setup from the Add/Remove Programs applet and removing the Advanced Logging feature. HTH, Tom
RE: MEMORY ALLOCATION FOR MSDE - 8.Jan.2006 4:30:45 AM
J.F.
Hello: If you want an easier way to display/edit the amount of memory MSDE can use, get the script named "ISA_MSDE_Max_Memory.vbs" from www.ISAscripts.org. It doesn't require OSQL.EXE and has just a couple simple command-line switches. Cheers, JF
RE: MEMORY ALLOCATION FOR MSDE - 9.Jan.2006 7:13:46 PM
Hi Jason, Thanks for the kind words about the site. We'll create a virtual mutual admiration society :) I'd be glad to mention your classes/consultation offerings in next month's newsletter. Let me know what you want folks to know. If you can post on the message boards that would be great! If you want to write some articles and be part of your author's group, send me a note at tshinder@tacteam.net and I'll get you set up and provide you some details. Thanks! Tom
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 8:43:17 AM
Covani
Hi guys, Many thanks for the links.. By the way i have decided to leave ISA Server free to have so much memory because: quote:
CAUSE Microsoft SQL Server uses the available physical memory to optimize MSDE insertion and query processes. SQL Server is designed to release physical memory as soon as there is a request for physical memory from other processes that are running on the computer.
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 6:54:42 PM
LLigetfa
While this may be considereed scope creep, I capped my MSDE because I was having problems trying to allocate RAM cache. http://forums.isaserver.org/m_340014500/mpage_1/key_ram%2ccache/tm.htm#340014500 I never did get a clear answer on the board and I cannot remember the details of what I tried. I don't recall now whether MSDE trumps RAM cache.
RE: MEMORY ALLOCATION FOR MSDE - 19.Jan.2006 6:31:38 AM
Hi Les, Runs great. I almost never see my MSDE process run higher than 60MB. I don't know why it *seems* to go haywire on some boxes. I've never seen any of those boxes in person, so I haven't had a chance to troubleshoot the issue. Tom
