MSMQ DMZ to LAN
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> MSMQ DMZ to LAN Page: [1]
MSMQ DMZ to LAN - 29.Mar.2006 12:21:26 AM
khowlette
Hi
I need to publish MSMQ server on the internal LAN so that the web farm servers can access them.  Presently the MSMQ servers are in the DMZ because the guy that left couldn't get it to work.  All the server in the DMZ are on their own AD domain.  When I move the MSMQ servers to the internal LAN they will be on the internal AD domain.
All the servers are Windows 2000
Has anyone done this.  I read a few MS articles e.g. http://support.microsoft.com/kb/q183293 but searching this site they appear from previous posts not to work.  Would IPsec/VPN be a possibility
Thanks in advance
Keith
RE: MSMQ DMZ to LAN - 29.Mar.2006 4:04:10 PM
Hi Keith,
What protocols are required?
(in reply to khowlette)
RE: MSMQ DMZ to LAN - 29.Mar.2006 10:44:57 PM
khowlette
Hi Tom
According to MS it uses
The following ports are used for Microsoft Message Queuing operations:
TCP: 1801
RPC: 135, 2101*, 2103*, 2105*
UDP: 3527, 1801
* These port numbers may be incremented by 11 if the initial choice of RPC port is being used when Message Queuing initializes. A connecting QM queries port 135 to discover the 2xxx ports.
I'm concerned about opening RPC from the DMZ to the LAN.
Keith
RE: MSMQ DMZ to LAN - 30.Mar.2006 5:17:36 PM
Hi Keith,
No problems with RPC. Remember the ISA firewall has an RPC filter that protects you.
Note that you'll need a ROUTE network rule for LAN to DMZ connections.
RE: MSMQ DMZ to LAN - 30.Mar.2006 9:49:28 PM
khowlette
Thanks Tom
Greatly appreciated.  I'll do some testing very soon
Keith
RE: MSMQ DMZ to LAN - 1.Apr.2006 9:06:11 PM
Hi Keith,
For the RPC rule you might need to disable strict RPC compliance. Try it both ways.
RE: MSMQ DMZ to LAN - 4.Jul.2006 5:16:36 PM
cellarstudio
I am having the same issue...I have a web server in the DMZ and I need to get MSMQ to send messages from the web server to an internal database server through SBS with ISA 2004.  I tried adding a policy rule to allow the required ports from the web server (192.168.1.106) to the internal database (192.168.16.5), but the outbound message queue only said "waiting to connect" (I'm using DIRECT TCP:192.168.16.5 in the MSMQ script)...and the message never goes.
I then installed MSMQ on the SBS server(192.168.1.100 -external NIC & 192.186.16.2 - internal NIC)and changed the script to "DIRECT TCP:192.168.1.100" and created a publishing rule for MSMQ.  The message makes it to the SBS server queue.  I have found a document for creating an XML document for redirecting MSMQ messages from the firewall server to an internal computer, but I can't get it to work.
How do I set up a direct connection over these ports from the web server to the internal DB server, so that I can use "DIRECT TCP:192.168.16.5"?
Thanks.
RE: MSMQ DMZ to LAN - 31.Jan.2007 6:22:20 AM
khowlette
Hi
I got it to work with the following  this doc http://support.microsoft.com/kb/319454
but I also had to allow RPC135 outbound on secondary connections.   Is this safe.  I tried with the RPC filter but couldn't get it to work.
I ran a scan against my ISA server and its only showing ports 1801, 2103 and 2105 as open.
My ISA is a backend firewall we have a Sonicwall PRO on the front end.
Keith
(in reply to cellarstudio)
RE: MSMQ DMZ to LAN - 7.Mar.2007 6:52:08 PM
khowlette
Hi
I've succesfully configured my ISA 2004 server to connect to my Clustered MSMQ server on the LAN.  Its caused me some head scratching but it now works.  If any one's interested let me know and I provide the details.  Its similar to Exchange RPC publishing but the UDDI are different for MSMQ.  There are some security gotcha's on Windows 2003 that  block remote read of queues.  What threw me for a while was that I could read queues from XP but not 2003 server, some registry hacks fix this.
Keith
RE: MSMQ DMZ to LAN - 7.Mar.2007 9:06:11 PM
Hi Keith,
It would be great to get the details.
Thanks!!!
RE: MSMQ DMZ to LAN - 14.Mar.2007 4:02:09 AM
khowlette
Hi Tom
I've created an article on my website which gives all the details
http://www.keith-howlette.com/techie.htm
Keith
RE: MSMQ DMZ to LAN - 31.Aug.2007 4:03:17 AM
bsingh
Clarify the following
In your article you have mentioned port 135 direction both. As  primary connection does not allow inbound and outbound so outbound may be defined in secondary.
Only two publishing rules you have defined is required for or any other access rule is required for RPC
bsingh
RE: MSMQ DMZ to LAN - 31.Aug.2007 4:27:00 AM
khowlette
Hi bsingh
Please check out  the article on my website http://www.khowlette.btinternet.co.uk/isa_msmq.htm .  The RPC rules are defined within the document.  Some of the early post I made were made when I didn't fully understand MSMQ but once I had it all working with the security I needed I published the article on my website.  Have a look at it and if its still not clear contact me again and I expand further.
Keith
RE: MSMQ DMZ to LAN - 1.Sep.2007 1:11:12 AM
bsingh
HI keith
Thanks for timely reply
I read your article , it well explained. Only Following is not clear to me.
You mentioned that following is to be included in MSMQ Inbond Rule
port |   protocol    | direction
135  |   Tcp    |  both
AS ISA 2004 allows inbond or outbond in same rule. Inform me How to include the above port in both direction in MSMQ Inbond.
bsingh
RE: MSMQ DMZ to LAN - 3.Sep.2007 7:46:40 AM
bsingh
I have made two rules as you mentioned in the artilcle (msmq inbond and msmq rpc) but log is showing 1801 unidetified denied connection by default rule.
in place of my server i have mentioned ISA server name directing to externel IP of ISA server.
Is any other configuration is required in ISA SErver 2004 or queue name mentioned in publishing server should also be on ISA server
bsingh
(in reply to bsingh)
