Making a IPSEC VPN Client connection work through ISA 2006
All Forums >> [ISA 2006 General] >> General >> Making a IPSEC VPN Client connection work through ISA 2006 Page: [1]
Making a IPSEC VPN Client connection work through ISA 2006 - 17.Jul.2008 8:52:13 PM
sander99
I'm in the process of migrating from WinProxy to ISA Server (standard) 2006 on a Windows 2003 server box. For some reason I can't create a VPN connection from my wireless laptop that is part of my internal network to my corporate VPN server. I was told the VPN is IPSEC based.
My ISA allows any outbound traffic from the internal network for any protocol.
I'm looking for help....
RE: Making a IPSEC VPN Client connection work through I... - 19.Jul.2008 10:54:56 AM
sander99
I ended up reapplying the Windows 2003 service pack. This fixed my issue.
(in reply to sander99)
RE: Making a IPSEC VPN Client connection work through I... - 19.Jul.2008 11:38:01 AM
You might also want to consider a possible RSS bug if you are using Windows Server 2003 SP2.
RE: Making a IPSEC VPN Client connection work through I... - 20.Jul.2008 1:39:46 PM
sander99
In fact, after applying servicepack 2 again (which fixed my issue) I found the reference to KB948496 in my event log. Just in case I applied the patch. I never saw this event log entry when I used to have the problem.
RE: Making a IPSEC VPN Client connection work through I... - 21.Jul.2008 9:40:44 AM
Yes, make sure you disasble the RSS and other scalable networking pack features after installing SP2.
