Max VPN users on Internal
Max VPN users on Internal - 27.Jun.2008 3:09:59 AM
IQ TECHNOLOGY
Hi all ISA genius I need some one give me an idea on the max no. of users can connected to the internal network There is no NAT or WEB or FIREWALL clients on the internal network , only VPN Clients And what is the pressure on the ISA Server Regards
< Message edited by IQ TECHNOLOGY -- 27.Jun.2008 3:11:19 AM >
IQ TECHNOLOGY
RE: Max VPN users on Internal - 27.Jun.2008 9:10:42 AM
paulo.oliveira
Hi, you can view the number os simultaneous connection by going to Virtual Private Network (VPN) - VPN clients tab and click Enable VPN Client Access. Regards, Paulo Oliveira.
RE: Max VPN users on Internal - 28.Jun.2008 3:13:57 PM
Q.How many concurrent connections are supported by ISA Server VPN? A.For ISA Server 2004 Standard Edition, the number of concurrent VPN remote access connections is limited to 1,000. This limitation exists even if you install the product on a Windows operating system that supports more than 1,000 concurrent VPN connections. Source : http://www.microsoft.com/technet/isa/2004/plan/faq-vpn.mspx
RE: Max VPN users on Internal - 29.Jun.2008 6:33:54 AM
mmm so you already have an AD, are the clients joined to the domain ? if yes and the users are logging into the machines users domain credentials , then no need to mirror the accounts. I was telling you that you will need to mirror the account if you don't have AD and your ISA Server & Clients are all in a workgroup. Now all what you have to do is to creat username and password usign AD, and then users will be able to logon to machines using domain credentials. Now that you have Active Directory and i assume ISA & client are joined to the same domain, then you are much better now than i thought. more info here : Debunking the Myth that the ISA Firewall Should Not be a Domain Member quote:
I have the Domain controller and AD and Files server on a single machine and the ISA on another machine ….. Thats great. quote:
when I disable or remove that user from my AD , it will not be able login to my network again ? Sure.
RE: Max VPN users on Internal - 30.Jun.2008 5:44:21 AM
The username and password are the one created in the domain controller and used to Logon to the Client machine. You said you have a domain controller. isa server and client are joined to it right ? how are you logging to these machines ? using local credentials or are you creating the required credentials to LOGON to the machine using Active Directory Users & Computers on the Domain Controller This will tell you how to join a machine to the domain : Join the Computer to the Domain and this article will tell you how to create a new user in AD : Create a User Account in Active Directory Users and Computers as mentioned before, these credentials are the one used to logon to the client machine. if you set the client as web proxy client, and set the proxy setting to point to ISA Server, then a pop up message will request from you to enter your credentials. and on ISA Server, instead of using ALL Users ( anonymous connection ) you can replace it with user/groups from AD.
