Messenger Configuration for Voice
Messenger Configuration for Voice - 26.Aug.2001 2:08:00 PM
zydone
I have try to get Messenger to use PC to PC voice communication but I can get to work do you have any ideas. I try the recomendations port tcp 6901 and udp 6901. Thank you.
------------------ Zydone
RE: Messenger Configuration for Voice - 26.Aug.2001 6:58:00 PM
Hi Zydone, See if this helps: Hi, for file transfers with the MSN-Messenger, you need scondary connections on Ports 6891-6900 TCP inbound and outbound. Also you must change the Firewall Client properties on the the ISA: "Application Settings" new entry. APP: msmgs; Key: NameResolutionForLocalHost; Value: P mfg Christian
------------------ http://www.isaserver.org/shinder/ Get It Here!
RE: Messenger Configuration for Voice - 27.Aug.2001 3:29:00 PM
zydone
I get MSN Messenger to do File transfer but the PC to PC voice communication is the one that I am having problems. Any other suggestions.
RE: Messenger Configuration for Voice - 26.Oct.2001 1:06:00 PM
kewitz
quote: Originally posted by zydone: I get MSN Messenger to do File transfer but the PC to PC voice communication is the one that I am having problems. Any other suggestions.
I have the same problem, did you solve it?
RE: Messenger Configuration for Voice - 7.Dec.2001 9:25:00 PM
clynn
I have this problem as well. Any luck?
RE: Messenger Configuration for Voice - 8.Dec.2001 9:10:00 PM
Hey guys, There is *no* solution for this problem. Not if you're behind an ISA Server. If you use the WinXP ICS, you'll be able to get all of these things to work. Until there's an update for ISA Server to allow MSN voice/video to work, you'll have to use NetMeeting and the H.323 gatekeeper. HTH< Tom ------------------ http://www.isaserver.org/shinder/ Get It Here!
