Multi network proxy
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> Multi network proxy Page: [1]
Multi network proxy - 10.Feb.2006 12:06:43 AM
nzaetta
Hi, Having a bit of an issue with ISA2004 on a trihomed box ISA server has the following IP's203.x.x.x192.168.0.30192.168.1.2 The main network is on the 192.168.0.x subnet and this works fine however we are setting up a dedicated link to a remote office on the 192.168.1.x network. I have no problem routing traffic between any of the networks however the clients on the 192.168.1.x network cannot use the ISA proxy server on 192.168.0.30 - the traffic gets to ISA as 'unidentified traffic' using port 8080 in an allow rule, (this is the same if clients on the 192.168.0.x network attempt to use the 192.168.1.x as the a proxy) and the client recieves the 'cannot find server or dns' error. If the clients on the 192.168.1.x use 192.168.1.2 as their proxy then everything is fine. So I guess my question is, should clients on the 192.168.1.x subnet be able to use 192.168.0.30 as their proxy? Thanks.
RE: Multi network proxy - 10.Feb.2006 2:01:00 AM
Why not enable the web proxy on the 192.168.1.x network for clients in this network?
You can do this with the web proxy tab on the network properties...
Microsoft MVP (Forefront Edge Security)
Silversands Ltd
http://www.silversands.co.uk
(in reply to nzaetta)
RE: Multi network proxy - 10.Feb.2006 5:58:03 AM
nzaetta
It is enabled, otherwise they wouldnt be able to use it as a proxy.
The question was, should clients on the 192.168.1.x subnet be able to use 192.168.0.30 as their proxy?  -- and if so, what might be preventing it.
RE: Multi network proxy - 8.Apr.2008 11:02:41 AM
lelletto
My problem is little bit different
In my networks i need each networks use different proxy port
is possible for you ?
I try to add a network Intenal2 with an ip range 192.168.8.0 to 192.168.8.255
configuring on it  a web proxy port to 3129
but seem do not work
an when  i type:
netstat .-an | find "LISTEN"  on a command shell I cant see my port in the list result.
what's wrong (my english i wrong i now but what else)?
thanks in advance
leo
RE: Multi network proxy - 8.Apr.2008 3:14:39 PM
Hey guys,
check out my blog Multi-Networking WPAD Support in ISA 2004.
(in reply to lelletto)
RE: Multi network proxy - 9.Apr.2008 9:41:04 AM
lelletto
Unfortunaly I can't apply a DNS or wpad solution I need tree o four proxy port
ortherelse I'll move isa in an other network branch to resolve the problem.
(in reply to spouseele)
