NAT Issue
All Forums >> [ISA Server 2000 Firewall] >> SecureNAT Client >> NAT Issue Page: [1]
NAT Issue - 17.May2005 8:36:00 AM
jimbob18
I have just installed a new ADSL PCI card (Zoom 5506 model) in a Window 2000 server. It will connect to the internet when ISA and the firewall are turned off but wont browse the internet when these are enabled.
After looking in the event viewer it seems that this message in causing the problem:
Microsoft Firewall failed. The failure occurred during Initialization of Network Address Translation (NAT) because the configuration property msFPCName of the key SOFTWARE\Microsoft\Fpc\Arrays\{E604C131-F3EE-4FAA-807A-D2D3BE044A4F}\PolicyElements\DialupEntries\{0FFDA907-1C4C-47CF-8FC6-9DAC7F001979}\Credentials could not be accessed. Use the source location 2.1927.3.0.1200.365 to report the failure. The error code in the Data area of the event properties indicates the cause of the failure. For more information about this event, see ISA Server Help. The error description is: The system cannot find the file specified.
I have checked the dialup entries and even recreated this entry but the problem still presists. Any ideas???
RE: NAT Issue - 19.May2005 6:50:00 PM
Sunny.C
need more info... How is your isa configured? What can't you do & on where?
(in reply to jimbob18)
RE: NAT Issue - 23.May2005 5:58:00 AM
Rickymag
Hello Jim,
You need to ensure that DSL is working before you use ISA with the DSL connection. By this I mean use the native OS DSL connection first. If this works ISA will hook into it and the connection will be successful.
Regards
RM
