NetMeeting call for Remote Office
All Forums >> [ISA 2006 Firewall] >> Network Infrastructure >> NetMeeting call for Remote Office Page: [1]
NetMeeting call for Remote Office - 5.Oct.2007 7:24:08 AM
auchanaka1980
Hi All,
   I’m running ISA Server 2006 STD version. My server has two network cards. One is LAN other one is WAN.
We have site to site VPN connection. Our management wants s to use the Net meeting. So how can I configure that? I’ll test the net meeting client for internal network its woring fine. Internal to internal working  fine.
How can I call to Remote site net meeting client? I have enabled the H.323 adding also. But when I call to my remote site one client it’s give a error message. (The Person you called is not able to accept NetMeeting Calls) why is that?
Please give me support.
THanks
aucsna
RE: NetMeeting call for Remote Office - 9.Oct.2007 7:15:04 AM
Install the Firewall client on both client machines
Disable the H.323 filter
Create an "all open" Access Rule between the two Networks
Make sure you have a Route Network Rule connecting the source and destination Networks.
(in reply to auchanaka1980)
RE: NetMeeting call for Remote Office - 9.Oct.2007 7:59:23 AM
auchanaka1980
Hi Tshinder,
thanks for your reply. other site users are not in same domain. how can i install the firewall client to them? there are using the Checkpint firewall for access the internet.
let says outside user want to call to internall users via NetMeeting how to enable the incoming call. (they dial to my public IP ). i can call  to public IP users.
any idea how to do?
thanks
aucsna.
RE: NetMeeting call for Remote Office - 10.Oct.2007 9:30:59 AM
I thought you have a site to site VPN connection terminating on ISA Firewalls on both sides.
RE: NetMeeting call for Remote Office - 10.Oct.2007 10:30:10 PM
auchanaka1980
thanks for your reply. So, other site use the Check point and my side ISA server. ther access internet there own server.
what i want to do is if some external client call to my internal NetMeeeting client. Incoming call is not Receving to My Internal Client.
My Internal Client can call to publick NetMeeting users. How can i receive the Incoming Netmeeting Call through ISa Server 2006.
Actually this question no one reply to me. i was inform to Microsoft Techincal support As well. Still no answer from them.
aucsna,
RE: NetMeeting call for Remote Office - 11.Oct.2007 10:40:43 AM
This won't work without an H.323 Gatekeeper, which is not included in ISA 2006.
RE: NetMeeting call for Remote Office - 12.Oct.2007 2:42:35 AM
auchanaka1980
i already enable the H.323 Gatekeeper on the add-ins.but still the same result. how to configure it?
Tks.
aucsna.
RE: NetMeeting call for Remote Office - 12.Oct.2007 8:14:15 AM
The 2006 ISA Firewall doesn't have an H.323 Gatekeeper.
RE: NetMeeting call for Remote Office - 15.Oct.2007 7:54:43 AM
auchanaka1980
thanks for your reply. when i go to ISA SERVER CONSOLE--->CONFIGURATION-->ADD-INS--> there i can see the H.323 filter
it's there know? i enable that also.
i'm waiting your answer.
RE: NetMeeting call for Remote Office - 15.Oct.2007 10:17:52 AM
That's the H.323 filter, not a gatekeeper.
RE: NetMeeting call for Remote Office - 15.Oct.2007 11:18:45 PM
auchanaka1980
thanks your reply. is it possible to publish one pc for netmeeting? i want to receive netmeeting calls for one machine? if you can help me to configure that.
aucsna.
RE: NetMeeting call for Remote Office - 16.Oct.2007 9:38:57 AM
I think someone on these boards shared a method to do this, but I don't recall the details. I do know that you need to disable the H.323 filter to make it work.
RE: NetMeeting call for Remote Office - 16.Oct.2007 11:04:24 PM
auchanaka1980
thanks for your reply. if i disable the filter. how to create rule for incoming and outgoing calls.?
do i need to publish the netmeeting server?
