New to ISA, Help with SSL and OWA
All Forums >> [ISA Server 2004 General ] >> Exchange Publishing >> New to ISA, Help with SSL and OWA Page: [1]
New to ISA, Help with SSL and OWA - 15.Aug.2012 11:04:20 AM
ittim
HI all, I'm a bit new to this so learning as I go.
We had OWA enabled over HTTP internally which worked well. Have decided to get it working on line on HTTPS.
I have followed the details outlined in http://www.isaserver.org/articles/2004pubowartm.html
and have now got stuck. - I have my ISA server in a DMZ. The ISA server can ping the Exchange server using the FQDN ok (I used a host file) I can also telnet into Exchange on port 443.
I have a machine sat in my DMZ which i'm using for testing. I cannot get that machine to telnet in. So I guess i'm blocked by my ISA configuration.
If i attempt to telnet in the log has a few entries (all in black none in red) but it seems to attempt to initiate and then close stating...
A connection was abortively closed after one of the peers sent a RST segment.
Now of course my internal users cannot connect to the OWA as I guess it needs to point to the fqdn because of the installed certificate (purchased not self cert)
The only place I appear to be able to access owa is on ISA server itself. Although it seems to suggest there is a certificate error. I'm pulling my hair out so any help is appreciated.
**Note. On an earlier attempt I had it working via HTTP on port 80
Many Thanks
