Not able to publish servers
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> Not able to publish servers Page: [1]
Not able to publish servers - 2.Feb.2007 5:51:49 AM
SadSam
I have problems to create working server publishing rule. Nothing seems to be working. For examble if I try to publish internal Terminal Server I only get 'remote desktop disconnected'-message. In ISA logging is:
RDP (Terminal Services) Denied Connection ...and result code: 0xc0040014 FWX_E_FWE_SPOOFING_PACKET_DROPPED.
Is this configuration problem? Have i forgotten to do something or am i doing somethin wrong?
RE: Not able to publish servers - 2.Feb.2007 10:39:19 AM
Hi SadSam,
please post the result of the 'ipconfig /all' and 'route print' commands on the ISA Server and the internal Terminal Server.
Also, what have you defined on ISA as networks and what network rules do you have in place?
(in reply to SadSam)
RE: Not able to publish servers - 2.Feb.2007 12:40:24 PM
SadSam
thanks for answering so quickly...
I started all over from beginning, installed server again and now i'm trying to get it right. Hopefully you can advise basic configurations so that there is easy to continue whit access rules. Propably the problem in the first place was in the routing...
Anyway what i'm trying to get working:
ISA with 3 networkcards
External:
IP: Public IP1, public IP2
Default GW
No DNS
Internal 1
IP 192.168.10.20
No GW
DNS1 Public IP3
DNS2 Public IP4
Internal 2
IP 192.168.99.20
No GW
DNS1 Public IP3
DNS2 Public IP4
Terminal server has now public IP5 with same default GW than ISA and with DNS1: IP3 and DNS2: IP4. For publishing throug ISA its going to be:
IP: 192.168.99.17
GW: 192.168.99.20
DNS1: Public IP3
DNS2: Public IP4
in Internal 1 network are workstations and to the terminal server has to be access from internal 1 network and external network. All servers are now in public IP:s (IP3 and IP4 are own domain controllers with DNS) and plan is to move then one by one to internal 2 network.
Now there is now extra routes in routing table and it looks like this:
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
         0.0.0.0          0.0.0.0       Default GW       Public IP1     20
       127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
    192.168.10.0    255.255.255.0    192.168.10.20    192.168.10.20     20
   192.168.10.20  255.255.255.255        127.0.0.1        127.0.0.1     20
  192.168.10.255  255.255.255.255    192.168.10.20    192.168.10.20     20
    192.168.99.0    255.255.255.0    192.168.99.20    192.168.99.20     20
   192.168.99.20  255.255.255.255        127.0.0.1        127.0.0.1     20
  192.168.99.255  255.255.255.255    192.168.99.20    192.168.99.20     20
     public.0  255.255.255.192       Public IP1       Public IP1     20
      Public IP1  255.255.255.255        127.0.0.1        127.0.0.1     20
      Public IP2  255.255.255.255        127.0.0.1        127.0.0.1     20
      public.255  255.255.255.255       Public IP1       Public IP1     20
       224.0.0.0        240.0.0.0    192.168.10.20    192.168.10.20     20
       224.0.0.0        240.0.0.0    192.168.99.20    192.168.99.20     20
       224.0.0.0        240.0.0.0       Public IP1       Public IP1     20
255.255.255.255  255.255.255.255    192.168.10.20    192.168.10.20      1
255.255.255.255  255.255.255.255    192.168.99.20    192.168.99.20      1
255.255.255.255  255.255.255.255       Public IP1       Public IP1      1
Default Gateway:     Default GW
Persistent Routes:
None
In ISA there is now only Internal network (192.168.10.0-192.168.10.255 and 192.168.99.0-192.168.99.255).
No Network rules (only defaults) and no access rules.
Previously I tried almoust everything with step by step guides, wiht trial and error and finally with just quessing and finally i was so messed up that i decided to start everything from beginning....just need couple of good advice to get to the point
I hope so that this helps you to help me.
Thanks beforehand
Sam
(in reply to spouseele)
RE: Not able to publish servers - 2.Feb.2007 2:27:52 PM
Hi Sam,
aha... of course it won't work! You should first fix your general network setup.
Q1: do you really want that ISA Server controls the traffic between the networks IP 192.168.10.0/24 (internal 1: WKS) and 192.168.99.0/24 (internal 2: SRV), or do you just want to route the traffic between them. The former can be done but is not the easiest configuration to start with. In any case, if they are connected to different interfaces than they can't belong to the same ISA Internal network definition; they must belong to different ISA networks.
In fact you will have to choose between one of the following designs:
1. Network within Network scenario:
   Subnet A ---+
     .     [Layer-3]---[ISA] --- Internet
   Subnet N ---+
2. Your current scenario:
   Subnet A ---+
     .       [ISA] --- Internet
   Subnet N ---+ ]
Q2: may I assume that all public IP's belong to the same network ID? If that's the case, you can't split them up at will and use them on the internal and external networks. Moreover, how are things physically connected to each other? Can you draw a little diagram so we understand better your exact configuration?
< Message edited by spouseele -- 2.Feb.2007 2:32:56 PM >
RE: Not able to publish servers - 3.Feb.2007 12:29:59 PM
SadSam
Hi Stefaan,
here is how things are connected now and what was it planned to be:
Current
  Internal 1 : WKS ---+[Switch]---+
   SRV A -----------------------------!
       .                                        [Switch]--- [ISP] -- Internet
     SRV N ----------------------------!
    [ISA] ------------------------------+
Planned
  Internal 1 : WKS ----[Switch]---+
     .                                           [ISA]--- [ISP] -- Internet
  Internal 2 : SRV -----[Switch]---+
Plan was to move servers one by on to Internal 2 and publish them throug ISA. I started with TS because its looked like it could be the easiest one. Firstly Internal 1 and Internal 2 were in different ISA networks, but that was not working...
Public IP's belongs to same network ID.
Easiest way to do this would be the best one, (but does it mean that first i have to get a router between Subnets and connect that directly to ISA?)
Sam
RE: Not able to publish servers - 3.Feb.2007 3:01:08 PM
Hi Sam,
to be sure, do you really want that ISA Server controls the traffic between the networks IP 192.168.10.0/24 (internal 1: WKS) and 192.168.99.0/24 (internal 2: SRV)? Yes or No?
In your current configuration, do all internal hosts have public IP's?
RE: Not able to publish servers - 3.Feb.2007 8:43:09 PM
SadSam
Hi Stefaan,
Yes, plan was that ISA also controls traffic between Internal 1 and Internal 2.
In current config workstations have 192.168.10.0/24 and servers have public IP's
Sam
RE: Not able to publish servers - 4.Feb.2007 6:15:02 AM
Hi Sam,
OK, than you have to go for he following scenario:
   Internal 1 ---+
     (WKS)       !
               [ISA] --- Internet
   Internal 2 ---+
     (SRV)
This requires 3 ISA networks:
  • Internal 1: 192.168.10.0/24 for the workstations
  • Internal 2: 192.168.99.0/24 for the servers
  • External network (default)
and the following network rules:
  • From (Internal 1 + Internal 2) To External = NAT
  • From Internal 1 To Internal 2 = ROUTE
The reason for the route relationship between Internal 1 and 2 is that otherwise you might have problems with domain related traffic such as file sharing, etc..
Your problem is now how to get from the current configuration, with public IP's assigned to the servers, to the planned one in a smooth way.
Q1: How many public IP's do you have and how many servers?
Q2: Is it feasable to move and renumber the servers to the new network ID in one step?
RE: Not able to publish servers - 4.Feb.2007 4:12:23 PM
SadSam
Hi Stefaan,
ISA networks and network rules looks like (looks like, but not so sure anymore) what i was trying in first effort (when i tried to move TS to Internal 2).
We have 10 servers (+ ISA server) and as many public IP's in use (+ couple of spare ones). Propably it's not possible move servers in one step. It has to be done off-hours and timewindow is not so big. That's the reason why i though that best way is move servers one by and to get that configuration to work at the time....
So if there is way to do this....
Sam
RE: Not able to publish servers - 5.Feb.2007 3:01:48 PM
Hi Sam,
OK, can you clean up your diagram of the current network and repost it? It's hard to read now. Use a fixed font face such as Courier New. It will allign much better ;-)
RE: Not able to publish servers - 5.Feb.2007 4:49:23 PM
SadSam
hope it looks better this time...
  • All workstations are connected to switch 1
  • Switch 1 is connected to switch 2
  • All servers are connected to switch 2
  • Switch 2 connected to modem
Internal 1 : WKS [Switch 1]+
                  [Switch 2]--- [ISP] -- Internet
All SRV (including ISA)----+
My plan was
  • To connect all workstations to switch 1
  • All servers to switch 2
  • ISA internal 1 NIC to switch 1
  • ISA internal 2 NIC to switch 2
  • ISA external to modem
Internal 1 : WKS [Switch 1]---+
Internal 2 : SRV [Switch 2]---+
Sam
< Message edited by SadSam -- 5.Feb.2007 5:03:40 PM >
RE: Not able to publish servers - 6.Feb.2007 3:42:01 PM
Hi Sam,
what I was afraid of...
If I understand it well than your servers are *not* protected at all? No firewall in the path to the Internet? Also, the workstations use the one-armed ISA to get out?
OK, that means that as soon as you place the ISA server in the path between the servers and the Internet you will have spoofing errors because they belong to the network ID assigned to the ISA external interface.
Maybe the following temporary solution could be used:
   Internal 1 ---+
     (WKS)       !
               [ISA] ---+--- [ISP] --- Internet
   Internal 2 ---+      !
     (SRV New)          !
   Temporary -----------+
     (SRV Old)
I think that if you define a new network 'Temporary' with the 'old servers' in it and a network rule From (Internal 1 + Internal 2) To Temporary = ROUTE it might work. When it does, you can than migrate one server at a time from the Temporary network to the Internal 2 network.
BTW --- what device is *currently* doing the routing between WKS and SRV?
< Message edited by spouseele -- 6.Feb.2007 3:44:38 PM >
RE: Not able to publish servers - 12.Feb.2007 9:31:15 AM
SadSam
Hi Stefaan,
sorry that i haven't been able to answer for a while.
Situation is not so bad, there is firewall on the edge of internet.
[ISP] = [modem]---[router]---[firewall], but those are in hands of service provider. Does this change everything? I though that from outside view this doesn't matter...
I try to bend a model from iron wire.....
Your suggestion is following for a temporary solution:
  • all workstations (private IP's Internal 1 network) connected to Switch 1
  • ISA server NIC 1 with private IP from Internal 1 network connected to Switch 1
  • ISA server NIC 2 with private IP from Internal 2 network connected to Switch 2
  • ISA server NIC 3 with public IP connected to Switch 3 (witch i don't have but can obtain).
  • Also other servers with public IP's connected to Switch 3
  • In ISA server defined network Temporary with all public IP's (also ISA server's public IP?)
  • migrate servers one by one to Internal 2 network (and connect them to Switch 2) and make publishing rules from temporary network to Internal 2 network IP's?
   Internal 1 --[Switch 1]
     (WKS)       !
               [ISA] -[Switch 3]- [ISP] --- Internet
   Internal 2 -[Switch2]  !
     (SRV New)            !
   Temporary -------------+
     (SRV Old)
RE: Not able to publish servers - 22.Feb.2007 6:54:35 AM
SadSam
didn't work out...still not able to do any workable publishing rule.....can you give some further advice?
RE: Not able to publish servers - 3.Apr.2007 7:57:01 AM
SadSam
Hi again,
How I can get around this problem?
If I define network 'Temporary' to ISA with old servers public IP's and then move and publish one server I get those error messages because there is public IP which belongs to same network ID than servers in 'Temporary' network. Is there any method to do this without first changing servers IP's.
IP's currently in use are:
x.x.x.2
x.x.x,3
x.x.x.7
x.x.x.8
x.x.x.9
x.x.x.10
x.x.x.11
x.x.x.13
x.x.x.15
x.x.x.16
x.x.x.17
x.x.x.20
Mask 255.255.255.192
GW x.x.x.1
Servers needed to be publish have IP's x.x.x.7, x.x.x.9, x.x.x.13, x.x.x,15, x.x.x.16, x.x.x.17
Sam
RE: Not able to publish servers - 1.Jul.2007 3:38:20 AM
download2m
you can test this topics:
http://support.microsoft.com/kb/917025
& to to disable the IP Spoof Detection feature in Microsoft ISA Server 2004 :
http://support.microsoft.com/kb/838114/
Best Wishes
Mohamed Fathy
ERP Project Coordinator
MCP, MCSE, MCSA , A+ , NET +,
