OWA SSL Failed Connection Attempt
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> OWA SSL Failed Connection Attempt Page: [1]
OWA SSL Failed Connection Attempt - 11.Feb.2008 1:31:41 PM
zebo51
Two servers: ISA 2006 (domain member) and DC/exchange 2003/DNS etc.
I have had non SSL OWA published for some time and it works great.  Now I have a SSL cert and would like to secure OWA.  My setup is a simple Edge Firewall.  ISA box has one external NIC and one internal NIC.
My OWA site is owa.mydomain.com
My cert is for www.mydomain.com
I know I will get a warning on the cert name when visting, but that is not a concern at this time unless it is why things aren't working.  When I hit my site I get the FBA login home page.  I type in my credentials and then get an error page stating:
Error Code: 500 Internal Server Error.  The target principal name is incorrect. (-2146893022)
When looking at my ISA Monitoring, it logs a Failed Connection Attempt on my OWA SSL Rule.
Is this because my cert is for www. and not owa. or might something else be set wrong?
RE: OWA SSL Failed Connection Attempt - 11.Feb.2008 1:46:22 PM
zebo51
I found this article:
http://support.microsoft.com/kb/328917
Since it is referencing ISA 2000, the settings are slightly different and I tried a few different combinations without luck.
Am I waisting my time or should I be able to do this?
(in reply to zebo51)
RE: OWA SSL Failed Connection Attempt - 15.Feb.2008 10:47:52 AM
charlieit
The address people use to get to your OWA MUST match the certificate exactly!  So if they are going to https://owa.mydomain.com/exchange, your certificate MUST be "owa.mydomain.com".
Great Article to help you:
http://www.isaserver.org/articles/2004dmzfebe.html
Scroll halfway down to:  "Exporting the OWA/RPC/HTTP Web Site Certificate to a File and Copying it to the ISA Server 2004 Firewall"
2004 SP2 is so similar to 2006 you won't have any problems.
Good Luck!
Charlie
