Ok guys, im trying to publish OWA from Exchange 2003 through ISA 2006. I get the ISA login form, but when i put in user/pass the page just flashes real fast and puts me right back at the login.
I am having the same issue, i have checked the publishing rule. See Below, but i am still having the same issue.
Action = Allow From = Anywhere To = owa.mydomain.co.uk Traffic = HTTP Listener = SSL Listener (See Below) Public Name = owa.mydomain.co.uk Paths = /public, /oma, /Microsoft-Server Acti, /Exchweb, /Exchange Authentication Delegation = Basic Authentication Bridging = Redirect Requests to SSL port 443 Users = All Authenticated Users
Listener Netorks = External, Internal Connections = Enable SSL on Port 443 Certificates = (points to my certificate called owa.mydomain.co.uk) Authentication = HTML Authentication
Works a treat now, although i would like to use a customised logon screen that i made some time ago to replace the blue looking screen that i have now!! Is this possible? i customised the older looking logon screen.
Hi, You might want to double check your Publishing rule HTH, Dev
NSS. I'm sure he got at least that far in his thinking. Any bright suggestions like WHAT to check in the Publishing rule? It's not like it's just one or 2 options/settings. Please don't litter threads with replies which don't even come close to isolating/resolving the problem but indicate more desire to increase post count or general lack of knowledge. HTH, Steve
