Odd Traffic
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> Odd Traffic Page: [1]
Odd Traffic - 18.Oct.2003 9:06:00 PM
beanz
Hey all,
I'm having a problem creating a trust relationship between two NT domains so I decided to take a look in the firewall/IP logs (the domains are joined across ISA based VPN)
In the IP log I found there were a dozen or so entries every second for traffic to and from the external IP of each ISA server on port 45 and port 47.
Does anyone know what these ports are used for or what the traffic could be?
Cheers,
Danny
RE: Odd Traffic - 19.Oct.2003 3:10:00 PM
beanz
think I posted this in the wrong forum, sorry! Is there any way to move it??
Danny
(in reply to beanz)
RE: Odd Traffic - 19.Oct.2003 8:44:00 PM
Hi Danny,
check out http://www.networksorcery.com/enp/protocol/ip/ports00000.htm .
(in reply to beanz)
RE: Odd Traffic - 19.Oct.2003 9:13:00 PM
beanz
Thanks for the link.
What are the NI FTP(port 47) and Internet Message Protocol (port 45) for? Is it right that traffic is generated a dozen or so times a second all day every day??
Danny
(in reply to beanz)
RE: Odd Traffic - 19.Oct.2003 10:05:00 PM
Hi Danny,
I don't know this two protocols but are you sure you have seen TCP/UDP port numbers and not IP protocol numbers?
Please post an excerpt of the IP log. Just make sure you have enabled the logging of all fields and you have set the log format to ISA format.
(in reply to beanz)
RE: Odd Traffic - 19.Oct.2003 11:11:00 PM
beanz
Thanks for taking the time to look in to this for me!
I'll be able to post a "cutting" of the log when I get in work tomorrow.
Danny
(in reply to beanz)
RE: Odd Traffic - 20.Oct.2003 9:53:00 AM
beanz
Below is a couple of lines from the IP Logs. As mentioned earlier, these lines appear a dozen or so times a second all day every day.
2003-10-20 00:00:00 xxx.xxx.xxx.1 xxx.xxx.xxx.2 47 - - - ALLOWED xxx.xxx.xxx.1 45 00 00 20 6f d9 00 00 80 2f 00 00 d9 9e 70 82 d9 9e 04 8e 20 81 88 0b 00 00 c3 e7 00 00 ce 8b
2003-10-20 00:00:00 xxx.xxx.xxx.2 xxx.xxx.xxx.1 47 - - - ALLOWED xxx.xxx.xxx.2 45 00 00 68 1c 5b 00 00 79 2f d2 8a d9 9e 2e c2 d9 9e 70 82 30 01 88 0b 00 48 02 00 00 00 38 96 fd f8 70 ec 9d 0e 35 0a
The xxx.xxx.xxx.xxx denotes the external IPs on each ISA.
Cheers,
Danny
(in reply to beanz)
RE: Odd Traffic - 20.Oct.2003 7:55:00 PM
Hi Danny,
aha... just what I thought! [Big Grin]
The number '47' is listed under the Protocol field. IP protocol 47 is the GRE protocol used in a PPTP VPN connection.
Where did you see the number '45'? If you mean '45 00 00 20 6f ....' in the log then it is listed under the Header field and contains the IP Header of the packet.
(in reply to beanz)
RE: Odd Traffic - 21.Oct.2003 11:06:00 AM
beanz
So it's nothing to worry about then!??
What does the GRE protocole do?
Danny
(in reply to beanz)
RE: Odd Traffic - 21.Oct.2003 4:23:00 PM
beanz
Also,
A little off topic but do the Blaster/Sobig blocking scripts block any internal traffic accross the VPN.
I'd like to run them and get the filters/rules/protocols etc setup but am a little worried about the implications.
Danny
(in reply to beanz)
RE: Odd Traffic - 21.Oct.2003 9:52:00 PM
Hi Danny,
the PPTP VPN protocol uses TCP port 1723 for the control connection and IP protocol 47 (GRE) for the tunnel. Because you seems to run a gateway-to-gateway VPN scenario, that traffic must be considered normal! [Cool]
Traffic inside the VPN tunnel is NEVER inspected by ISA server because that traffic is considered trusted. However, if you don't trust that traffic you should not allow that VPN tunnel in the first place! [Big Grin]
(in reply to beanz)
RE: Odd Traffic - 22.Oct.2003 12:33:00 AM
beanz
Hey Stefaan,
Thanks for the info. Think I need to do some reading up on protocols etc!
RE the blaster/sobig scripts, while the traffic passing through/across the VPN tunnel is trusted is it worth running the scripts to prevent inbound traffic or does ISA block this by default?
Danny
(in reply to beanz)
RE: Odd Traffic - 22.Oct.2003 9:38:00 PM
Hi Danny,
do you mean the scripts available on isatools.org? If that's the case, two of them create just a deny protocol rule so the virus won't propagate to the external world. The other two is for scanning internal hosts.
If you have a good policy, that means only allow that what is stricktly necessary, they will not enhance your policy. Of course if you have an open protocol rule (all IP traffic) then they will block the protocols used in the propagation of the virusses.
(in reply to beanz)
